Your big valves helping or hurting?
Are you using pods or an air box?
Apexi pods and hurting spool helping top end. Before the latest mods it's a pretty normal figure 400kw on 98 for a nicely built 26 with stock valves always thought something may have been holding it back considering the amount of head work iv had done.
"Clearly" shoot 4?? :)
Iv been considering returning to stock airbox to till I noticed one of my plastic turbo to afm pipes completely chewed up by a hungry possum in the shed wasn't fn happy.. If I get time in the next few months I'll return it to stock and re test id prefer the stock look.
Unless you are opening the ports to 90% of the valve head ratio don't bother with bigger than +1.0mm exhaust valves. The bigger valve head can also hurt flow in a small bore. Moreso a problem on intake though.
Yep close about 4300 on pump but I think around 3800 on e85. I still believe my +2mm Exhuast valves effect spool a bit... Not only was it a smallish outlet on the manifolds but there could have been a nasty square edge in the mix aswell I really should've matched it up earlier but got lazy...
hot damn. your spool is comparatively very good, imo. what cams? dumps? boost control info? timing?
How do you work that out exactly? :huh:
You - 175km/h @ 7000rpm (4th)
RPMGTR - 230km/h @ 8000rpm (4th)
You are doing 150km/h @ 6k, 175km/h @ 7k... So roughly 200km/h you are 8k
Meaning yours is the shorter ratio... So of course yours appears more responsive.
Ben's dyno using 5th, mines 4th gear.
Ben's getting 28.7 km/1000rpm. Std is 33.5 5th and 25.5 4th. Half way between.
Ben tends to use 5th gear as it give less gear box loss, 5th is 1:1 ratio.
Unusual he starts the dyno at 3000 rpm
isnt the idea to run the dyno in 1:1?
Depending which gear you run it will give u a higher/lower torque readout...
Hp should still be the same yea?
Though I guess depending what gear the car is in it will effect how much load is on the engine causing the curve to move left/right relative to load
No gear ratio will only change the tractive effort or the actual load through the load cell. In a perfect world the gear ratio shouldn't make a difference in measured hp or only be slightly different due to the differing thrust loading through the gearbox.
In reality even the good dynos show a slight difference between say 3rd and 4th gear probly due to unaccounted for acceleration rates.
The ramp rate is really the only thing that should influence how a turbocharged cars power delivery is plotted. Slower ramp rate gives the turbocharger longer to spool hence moving the graph to the left.
In my opinion, exactly.
Dyno's are set up to give a fixed road speed increase with time, e.g. 12 kph/sec.
If you use a taller gear the dyno stills holds the wheel speed to 12 kph/sec, giving the dyno sweep longer time from start to red line.
This then gives the turbo's more time to spool. Should give a quicker spool up , not by time but by road speed, which is what the reads.
I prefer dyno runs in rpm not road speed. This shows what the motor is doing more acurately than the unknown gearing of the car.
People on this thread do not even knowin what gear Ben's run was done.To me it seems 5th with a 4.1:1 diff. Only way to get 230 kph at 8000rpm.
He does use 4th sometimes,and 5th soetimes. He tuned my R32 GTR many years ago, great job too.
Since when is 5th gear 1:1 ratio ?
4th is 1:1 , 5th is 0.752
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
