Got Over 400kw Atw?
T04GTR
Your running rwd though aren't u Dave?
That extra tractive effort that the front wheels give are what give the box a harder time
True, but I use MT's all the time now, holds traction in second (when warm).
Hell of alot of load IMO, but yes driving style would have to be one of the biggest factors.
i also ran the 1/4 mile with a stock box in my previous gtr which made 320awkw & managed a 11.1 sec with 129.75mph.
that was my last run, however, i crossed the line in 3rd gear & was bouncing on the limiter & my 60 footer wasn't that good (1.6sec?)
considering the relatively low power level i had at the time (hks gtss @ 23psi) that car was capable of a 10sec pass, but unfortunately i fudged it over the line :(
breaking boxes i think comes down to the driver & treating the box with respect, i.e. no flat changing
good time for that power and 1.6 isn't a bad 60 foot, but 129mph in 3rd ?
Plenty of room for improvement, Jez.
Quickest on stock box is mid 9's with over 550rwkw!
what car is that out of interest?
And yes, driving style makes a big difference to box survival...couple that with the fact that most of the boxes are over 20 years old.
age is also a big factor after talking to terry @ award diff about this in the past
i also ran MT drag radials which have a larger rolling diameter, how accurate is the timing equipment @ WSID?
my relatively certain that my limiter back then was set to 9krpm (i know it was a tad lower than my 3ltr which was set to 9.5krpm)
i actually have a pic of my car on my old HD and it looked fat with those MT's - i couldn't believe how much it filled out the guards with the 16's.
i also have my timeslip - i'll dig it out, if only i can remember where ive stored it after major home renovations.
Dave, how are you finding the MT's for regular street driving?
Unreal! Not going back to street tyres on the rear.
They are 275/17s at 20psi, im hunting around for some in 18s to throw on my street rims.
Stock box in my 430rwkw GTR, so far has done approx 2500kms of track work. Not a problem with the box, survives 2nd gear tyre warmups on slicks and 8000rpm launches with an OS GIken triple plate. Mechanical sympathy is a must - and far cheaper than a replacement box..... Of note this setup has not been on the drag strip (no track in SA) and I realise that a proper hookup on a prep'd track would probably kill it :-)
This warms my heart <3
Has anyone here cryo treated their box ?
I've been told it's effective but have my reservations.
Yes, both gervaise and I had our box's cryo treated at Dans insistence.
both car make over 400 kw's and both get dragged and circuit driven and have done for 3 years with zero gearbox issues.
Does it work, How do you prove it. You can only disprove it by breaking the box and that has not happenned to date so I'm going with a resounding yes! It does work.
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
