Matt Tang was telling me his vcam RB28 would push the -5's into surge occasionally. A combination of the added displacement providing a little more exhaust flow than a 26, and vcam inducing more overlap to to gain more mid range torque earlier in the rev range. The advice I heard Racepace gave Matt was that the surge could be tuned out, but at the expense of low end torque, most likely making the vcam retard the intake earlier.
So what we can take from this is that if your engine is optimised to the limit, even -5's will push into surge.
(I'm talking surge here, not shuffle... don't confuse the two)
My -5s will surge only on a 5-8 degree morning, full load in 5th coming onto boost. Could be tuned out if i really wanted as you said, any warmer and it was fine so it wasnt a problem. It was more conditions than anything else - such a rare thing that happens maybe once/twice a year.
What is the difference between shuffle and surge as I am not aware?
Same thing, different words
In your case Ash they'd retard the ignition which would make more doey to drive when its hot, and not as fun when its cold...I'd rather have surge than shuffle.
Shuffle can be seen on a data logger when the airflow values read from your twin maf sensors wildly fluctuate. I had big problems with this at around 1800-2000 rpm with my GTRS's as they start making around 0.4kg/cm under full load at this speed. However as exhaust flow isn't enough to spin the turbo's up to wastegate opening speeds, and the engine is running in a vacuum at the throttle bodies the effect is that one turbo will spin up and stall the airflow into the other. Once this happens the exhaust pressure in the stalled turbo swings the shuffle the other way. The GTRS's suffer for this because the compressor is too big for the turbine.
This is why a HKS balance pipe exhaust manifold helps dampen the effect. Also it explains why the split/baffeled twin turbo pipe helps so much, as it allows air velocities out of each turbo to be established before mixing them back into one air stream before the intercooler.
For me, I still get shuffle if I stand on the throttle in 4th at 2000 rpm. It will shuffle (till full boost at 5000 rpm), where exhaust flow and back pressure is sufficent to overcome the shuffle effect. You can drive around this though as really you'd drop back to 2nd or third anyway if you wanted to go faster.
Surge won't effect response, in fact surge is the result of too much response (for a given engine speed). The turbo's are being over driven by exhaust gas flow for a given engine speed. The rate of airflow into the engine (from the filters to the intake valve) is below what is the optimal air speed for the given compressor speed. The effect is your turbo makes terrible sounds as the airflow stalls out and bleeds back to the intake of the turbine housing, which can lead to turbine damage.
I hope that makes some sense. Im operating on minimal speel and 2 glasses of red at the moment...
I'd argue the point of surge not hurting response, if its bad enough it can basically have the car "stall" at a given point in RPM until it pushes through.
If low enough in the RPM this can take quite a while.
When i can get mine surging, low rpm/5th/6 degree ambient - it will not go past that RPM point at all even if i hold it there for 10 seconds. I have to drop back to 4th, pass that RPM window (about 300rpm) and then it's fine.
They way I understand surge is that airflow stops because it cant go anywhere, except bleed back out the turbo inlet, so would I be rightin think that airflow stops or even reverses to an extent?
I remember my old highflow would surge like crazy at around 3000rpm in 5th when cruising down the highway, send the PFC Haywire and the motor would cough and splutter then clean up for a few seconds and repeat
could hear it surging a mile away...like a Chappel st VL lol
driving down the highway going tutuutututut constantly
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
