^^ u should know, your a massive keyboard warrior.
You can't upset me tonight man, Crows beat Port in showdown.
I can't remember, when I looked into the Autronic 3yrs ago for my GTR you still had to run wasted spark.
plugin Links/Vipecs are wasted spark i'm pretty sure, only the wire-ins are sequential
i remember asking Rob @ RIPS about it, said he didn't really see the need unless it was a serious motorsport application.
My Civic had just a little under 400kw.
K20/K26 (JDM K20A2 Head)
Darton MID Wet Sleeves
4 Piston Racing Crank
CP Pistons (9.0:1CR)
Pauter Rods
GT4088
16psi made 520.80hp.
Geesus.. show us your torque steer eh?
exactly what I was thinking, being a fwd it would have major traction issues BUT making that power is easy with any engine as it is just an air pump...put a big enough snail on it and it will make the power
the plug in vipec and links are non sequential batch fire. aka z18et spec..
the wire ins are the way to go. the fact you have to hack up a standard ecu case to fit them aswell is a pain..
the haltech is quite good as it has all the built in knock control and is a "plug and play".
rb25 has forged pistons and rods, n1 pump with crank collar and ross "power steering belt flinging" balancer.
they have 4 ignition drivers and 8 injector drivers on the skyline plugin and come standard with a 3bar map sensor as of june/july last year (2.5bar before that).
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
