Also interestingly (this is always an interesting topic) - Nizpro only use 63mm on their 400rwkw+ XR6 setups. They are taller than a GTR item, but not as wide (they are bolt in replacement).
Now those cars have the MPH to back their power levels (130mph+ in a FG FPV), so they certainly aren't being restricted by any means of the word :)
Well different kettle of fish my friend, 4000cc motor that is capable of 400kw (lets not mention the 1000nm of torque at 3000rpm lol) at alot less boost pressure than that of our little 2600cc milk crate motors.. In saying that i dont know really know much about XR's but thats the direction that common sense seems to point me towards
No.
Now this one i will agree with you on :P
Is there a thread discussing tie down methods to hold gtr's onto the dyno properly? I will be booking more dyno time soon and want to do all the tuning in 4th so I can compare my results to what everyone else does.
What has boost pressure got to do with it? Its about the volume or air/airflow through the cooler and its ability to cool it with as low a pressure drop as possible. Coolers work efficiently when they have turbulent flow through them as all those excited air particles bounce off the wall of the intercooler and allow them to transfer heat. So by nature anything that cools will have a pressure drop across it. Otherwise a straight bit of pipe would offer less pressure drop , but of course nowhere near the cooling.
So I suppose you can make the assumption that a turbo at 18psi may have cooler outlet temps then something spinning 22psi. But hp is hp and requires a certain amount of cfm to achieve. So whether its a 4L at 6,000rpm or a 2.6L at 8,500rpm...an intercooler doesnt care or know the difference. It just has to pass air and cool it
Check our card's channel on YouTube. You will see how jim ties his gtr's down on his clips.
Usually runs a loop inside the cabin with both doors open and ties it towards the rear of the car.
Yeah Ive seen that method before. I'll have to see if the shop I use have ancors on the floor behind the doors.
Your 5 th is 1:1 though Ian as is R32/R33's 4th. Although you have a slightly taller diff ratio.
True, but I've noticed that a lot of the other R34 dyno sheets in circulation (from known tuners like Racepace and RIPS) seem to be done in 4th. The only reason I want to use 4th is for comparison purposes. Roller speed maxes out around 200km/h in 4th at about 7500 rpm from memory.
Dyno sheet in RPM rather than road/roller speed?
My dyno sheets have had both so far.. but the sheets I am aiming to compare too don't. And while 4th gear vs 5th gear results should produce very similar power figures, the torque and boost response curves are completely different. On the street I'll get full boost at 4500, but on a dyno the car wants off the rollers if it is loaded up at 12km/second to achieve the same response curve.
lol Dan! :D
i love how you ask loaded questions when you know the answer - i know, ya know.
I know Racepace do use "dyno wheels", just a set of R34 GTR rims with tyres for a lot of cars when doing comparo's etc. That way at least everyone uses the same rim/tyre combo. Also so that people don't have their semi's chewed out given the cars that go in there.
I think doing it that way is a good idea for parity sake. Im not sure other workshops do the same, however I've seen some that do so depends where i guess.
So because this thread is full of sooks who want NA response and big block Chev amounts of torque rather then old school kick in the ass when the big single hits....I am curious to know of those making 400rwkws, what power are you making at 4,000rpm and 5,000rpm.
Agreed.. you wouldn't think changing the intake would be a restriction though would you.. you think that would be the least of the restriction...
Anyhow - just pointing out they 'change something' when getting up to those levels.
I'll have to do a back to back myself someday just for interest. I'd like to log the intake temps and pressure drop over a known 'load' etc and see what happens.
3500 RPM = 140 RWKW
4000 RPM = 190 RWKW
4500 RPM = 260 RWKW
5000 RPM = 350 RWKW
5500 RPM = 395 RWKW
Peak power is 426 @ 7500 RPM
8000 RPM = 415 RWKW
Have you got the same figures for GT-RS's handy?
I only have these figures on me right now;
3000rpm = 150rwkw
4000rpm = 235rwkw
Thats compared to the old setup;
3000rpm = 70rwkw
4000rpm = 120rwkw
Should add, not that it's slow, but these numbers are done with the wrong cams, i'm certain a cam change will net a bit more gain but with a new engine on the way the current one will stay as is and nothing be changed on it before its removed and stored somewhere
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
    • I promise there will be no chance of replacing the rad support....  It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
