Thanks that would be great!
I'd be keen to hear more about lowering the engine. I know several RB30's have been put in at stockish heights, but everyone seems to do it differently. There's a market for bolt in mount kits, so everything needed to install RB30 to R32GTR in one package.
that guy simon has the worlds best kept secret on lowering the engine but he won't let the cat out of the bag
.I have 1 theory which I've discussed with another mechanic and would work
I heard of a trick using rb20 engine mounts which lowers it 10-15mm. Though dont know how accurate that is as I havent done it myself.
How much lower would the engine need to sit in order for the timing cover to not hit the bonnet bracing? Would 20mm drop be enough?
I recently did a 26/30 for someone. It required an 8mm drop, bonnet support cut out towards the front and the twin turbo 'badge' shaved off the twin turbo pipe to make it smooth.
With all that, it only just touches by a whisper.
With a standard bonnet I'd say 25mm would see it clear with no other changes.
I'm fairly sure RB20 mounts are the same height as GTR but I could be wrong. The other problem with lowering the engine in the subframe is the clearance between the sump and the subframe is only about 15mm at best from factory. You could possibly go 10mm of that but I reckon driveshaft clearances would have to be considered if you did
exactly what i did to mine - cut the bonnet brace above the front cams, took off the twin turbo badge & milled off the boss for the badge.
funnily though, i had to run the bonnet without the insulation as this was starting to rub the paint off my newly painted covers. that is how tight it was under there!
I was thinking if you could achieve say half inch of lowering engine towards sub frame via engine mount mods and then lowering sub frame half inch off chassis rail then you would be pretty damn close and both of those things are very straight forward and have probably been done before. But as you said you would need to look at drive shaft clearances and angles.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
