Squeezed my in-bred 25/26 tonight. 446kw @ 1.5bar
RB25neo with 2.6 crank/pistons @ 9.5:1CR
260 9.15 Cams with VCT
GT3582R .86 rear
Dry sumped
Sucrogen E85
Vipec ecu
nice!!
what internals were used in the build if you don't mind me asking?
block machined , balanced , honed oversized 0.20
crank , remachined and re heat treated , oversized acl race bearings
rods , shotpeened and prepped rods with oversized acl race series big end bearings
pistons arias forged 0.20 oversized with acl race series rings ect
tomei oil restrictor
cossworth 1,5mm drag series metal head gasket
n1 water pump
nitto high flow oil pump
nismo low temp thermostat
trust oil filter relocation
tomei sump baffles/trap doors
brand new gasket set throughout
head reconditioned with
hks step 2 cams and valve springs quite lumpy
slight porting on exhaust side
greddy adjustable cam gears
turbos , brand new garrett -5 turbochargers
hks non turbulent dump pipes
twin 3inch up pipes with 3inch magic cats (100cfm)
single 3.5inch high flow system
5inch rear cannon
autogallery yokohohama/os giken 1-5 gearbox , custom double cone syncros , hd mainshaft , hd input shaft , one piece billet 5th gear built by terry at award in sydney,,,
brand new os giken twin plate clutch
vspec active rear lsd and axles ect
nismo 320kmph dash
apexi power fc commander with hand controller
blitz ebc
injector dynamics modified 1000cc injectors on standard rail
turbosmart adjustable fpr
bosch 044 pump
splitfire coilpacks
hks dli twin spark amplifier
tien adjustable suspension
Stock RB26 including stock cams
Precision 6262 .8 twin scroll
6boost twin scroll with twin tial 38mm gates
Custom dump and plumb back pipes
LINK ecu
ID2000 cc injectors in stock rail
Walbro 400lph
Running semi slicks on the dyno too
Gate pressure
E70
  • 1 month later...
thought i'd ask in here as opposed to starting a new thread.
Midori has some 90mm front pipes now... i've got 80mm ones and not 100% on what mm the catback is... given the increased kw #'s we're putting out with E85 etc... would there be much gain in going to some 90mm front pipes? or is it waste of time unless the rest of the system is 90mm??
