Fuel cooler is mounted at front of car . In front of radiator, behind grill. A/c condenser has been removed oil cooler is also mounted in its location. I didnt like the oil cooler mounting in front of front wheel..I'll try track down some pics
Yea I've got my oil cooler in front of my front wheel, I don't think it's very effiencent there
My 83/75 results is a page or 2 back
The fmw has a different wheel design yea
My 32 gtr was rebuilt with the following parts and was run in and tuned by Sean at EFI Performance
Engine:
Rb26 (2.6l)
Cosworth forged pistons (87mm)
Manley conrods
R34 gtr crankshaft ( new from Nissan)
Acl race bearings
Arp rod, head, main bolts
Reimax billet oil pump gear
Tomei 1.5 mm head gasket
Kelford 282 cams
Manley valve springs with ti retainers
Sump baffles
Oil cooler
Balanced and blueprinted
Os giken twin plate button clutch rebuilt by NPC
Machine work done by chilton engineering
Engine assembled by Dan at ERD
Greddy plennum
Greddy 100mm pipe kit
100mm intercooler
Turbonetics billet gtk 1050 turbo with .86 twin scroll rear housing
Turbosmart 60mm wastegate
2.5 inch screamer pipe
6 boost exh manifold hpc coated with egt ports
4 inch dumpipe
3 inch decat pipe
3 inch TItanium cat back exhaust
Magnafuel 750 pro tuner fuel pump ( 2000hp)
Bosch 044 (lift pump)
7 litre surge tank
Fuel cooler
Aeromotive fpr
Bosch 2200 cc injectors
All braided hoses
Splitfire coil packs
Power fc dejetro
Car made 650hp at 26 psi (485kw)
I will post a pic of Dyno chart soon.
The ignition system is at limit at 26 psi
I have just finished installing ls2 truck coils and an ati balancer. Next tune the boost is being increased and rev limit is being increased.
Aiming for 700hp + on 30 psi.
Will post results when it is sorted.
Thanks, no port work on head just reconditioned with valve springs, retainers, shims etc.
Running on Caltex eflex atm. This setup needs to be run on drum E85 to get more out of it. The motor/turbo can quite easily handle 40psi. Not too confident on the consistency of pump ethanol. However, this is still a street car and 650hp should be enough for the std gearbox atm...lol.
