yes please that would be great
i go to regular track days with 30 minutes session( i actuively hunt these out as they are more fun)
mind you i dont have 400 gigawhats
With 400wgw who needs a rollers when you can turn the planet? :cheers:
  • 3 weeks later...
Hi guys recently got my e85 fuel system done....my car previously got 380 kW. Now with a 5ltr sard surge tank, 2000cc injectors I'm producing 450 kW on 25 psi. The to4z turbo was maxing out. I'm now planing on putting a precision 6466 turbo for more boost and power the aim is 500 + kW
Here my dyno graphs
Here my dyno graphs���
Very nice - is it an RB30? Surprised the T04Z was maxing out that early... what hotside are you running? Either way, 6466 will potentially improve both spool and power - be awesome to see an overlay if you do the upgrade, and are able
yeah it is an rb30 with a single inlet manifold.
We recently had our car tuned by Unigroup and made 485rwkw on 25psi and E-Flex. Didnt put any more boost into it due to stock head studs and the guys didnt want to risk lifting the head. The car is running a 6766 split pulse with a 1.0 rear end. It used to make 425rwkw with the old T78 at 25psi so we are very happy with the new turbo. Response is very similar which is the main thing ;)
Here my dyno graphs???
Mark Robinsons old car ;) You were picking your car up when we were dropping the S14 off from memory. Wil be nice with the 6466 on it though get Yavuz to overlay your graph with ours and see if the 6766 may be a better option :) You will make slightly more power with the 6766 with very very minimal difference in response
yeah I seen the s14 it's nice. Yavuz did say it will be a lot better with a 6466 said should be pumping 500kw just hope there is not much lag with that kind of power I got real good mid range atm
Thanks mate.
Although its changed a lot i spent quite a bit of time working on your car back in the days when Mark took it to Advan, it was a neat car back then and i am sure its just as neat now ;)
Direct comparison is pretty easy here, same dynos, same operator ;)
We have a 6766, 1.0 split pulse exhaust housing on a Trust T88 manifold, high boost we made 485rwkw at 25psi
4400rpm, we make 19spi and 200rwkw, your making 20psi and about 260rwkw
4500rpm we are making about 20psi and about 225rwkw, yours is making
5000rpm we are making 25psi and about 360rwkw, your making 25psi and about 390rwkw
but its when we get up into the revs that it makes a difference
where yours pretty much flat lines at 5600 and 440ish rwkw and 25psi, ours continues to climb. At 6400rpm we have 450rwkw and it continues to make power through to the 485rwkw peak and 8500rpm redline. We used to rev it to about 9000rpm but i told Yavuz to back it off a little lol
In all honesty its probably easier to get Yavuz to overlay the power curves on the dyno to gain a decent comparison
The Precision turbos are an awesome thing. You will be pretty impressed i reckon.
How are the torque curves in comparison.
I think I had the shift light set for 6500 as this kept it in the fattest part of the curve. It was also limited to 7500.
I have been told that revving the old 3.0ltr past 7500 is waiting for trouble.
But then I did nanny the old girl(well as much as you can nanny a car at the track or strip).
How's the traction, or lack of it, it was loose when I had it at only 380.
Excellent results, hope the drags went well.
I didnt see torque to be honest. I also dont read a lot into dyno graphs as they are only a turning tool. It was just pretty easy to compare these two cars as its the same operator in very similar weather conditions
I do know however that the car weighs in at 1440kg's with me in it and has run 137mph. That was with the old T78 so with an extra 55 odd rwkw i am sure its going to go 140mph plus fairly easily. Not bad for a car that gets driven to the track, put on some ET Streets and drive it home. I dont even take out the sub box ;)
Hey mark great night tonight at the creek. It was hard to get traction at first but then I got the air pressure right. warmed up tyres and got an 11.101 f**ken heaps happy with that. post-120788-13849530142997_thumb.jpg
Thanks mate.
oh good to hear bud can you send pic of your graph if u don't mind. At the end of the day if I put a precision 6466 I think it would hold like yours to, because Yavuz said should get a result of 500+
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
