Yeah the R3C is savage ( and has seen off half a dozen gearboxes ) but I've done about 40k kms in a few years and am impressed with its durability. For example: the other day I limiter launched twice in second thinking I was in Rwd but was in max 4wd . I reckon that would be enough to fry most clutches. I do agree the R3C isn't the right clutch for us, but in the right application ( not sure what that is ) I reckon it would be awesome.
Rb26
Eagle rods
Cp pistons
Tomei type b cams
Tomei gears
Mild head porting
Exh manifolds ported
Rotomaster 2860-5
2200cc injectors
120mm intercooler
Adaptronic ecu
Lc-1 wideband
Tomei dumps
Jim berry full Monty clutch
Apexi front pipe
100 cell cat
3.5" exh to x force cannon
B/c valve springs
Mac valve controlling boost via ecu
Best run of 360. On low but left it fat at 350 ish 19 psi
426 kw on 26 psi both united e85
Interestingly was 415 and we cracked airbox (std) and jumped to 426 so I will mod it. Another tuner said couldn't crack 400 with pump (walbro e85) and airbox or that I couldn't go over 24 psi on -5 guess he was wrong
Link to low boost run
  • Like 1
Rb26
Eagle rods
Cp pistons
Tomei type b cams
Tomei gears
Mild head porting
Rotomaster 2860-5
2200cc injectors
120mm intercooler
Adaptronic ecu
Lc-1 wideband
Tomei dumps
Apexi front pipe
100 cell cat
B/c valve springs
32 airbox always has been an issue. 33 on much better design, dual feed etc.
Good solid result. Be interested to see you go hit the 1/4! Too many '400rwkw -5' GTRs around at the moment that are failing to hit even 124mph let alone the 128-130 they should be, at least half a dozen now :/
10s gonna be EASY for you though me thinks, no fudge with your dessert! :thumbsup:
  • Like 1
I'm keeping the airbox but will modify the lower half and sheild the area where the snorkel was, I'm really concerned about traction even with semis although a bit hard she looses traction in 3rd gear on high boost, is this common with 400 plus Gtr ? Thanks for positive comments guys and thanks to jez for a job well done. I had a few issues he fixed , a restrictive tee piece, and failing alternator which actually makes a huge difference to tuning. Again jez is best, the flames are less common now but I'm glad I got a vid of it lol
It's really too bad my old Autronic SMC can't do flex fuel. I'm going to run a similar set up to Scott's with bigger cams. Change of fuel pump (and e85'n my system) would see 400's. So tempting but may have to wait for the next minor round of upgrades.
Great result there Scott! Really has me stoked for my build that will be similar -5 based set up.
It was good experience all said and done and jez is very patient although his initial words of he likes difficult cars came back to haunt with this puppy lol, jez do u rekon leave box for street and switch to pods at track? Wish I bought them with me for testing bugger.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
