My r32 rb25 went 419kw at 25psi on Eflex today.
Specs are:
Rb25det
Je pistons 1mm over
Eagle rods
Tomei poncams
11mm head studs
Greddy plenum
.82 Gtx 35 on 6 boost
Twin o44's and Id 1000's
Hks type r intercooler
3 inch exhaust
Starting to worry about the 33 box now so a power glide is on the cards next. Its pretty much a daily driver and i cruised home after it went on the dyno this arvo with the A/c cranked :)
Edited by 466OTS
  • Like 1
Whats the ideal manifold for a precision 6262 on rb26 I dont mind if its mild steel . Anyone .?? Im thinking of changing with my new build just trying to add up the $$$ and compare
Personally i would run anything other than a 6boost on a car that makes decent power. They may be on the expensive side. but htey are tried, test & proven.
When you have big $$ spent on a build, its work forking out a bit extra on a manifold I think
is there anything equilevant to the 6 boost at all ? and what would you expect to spend on the turbo itself and setting it up on a rb26
Yeh, because getting shit service is just as important as a good flowing manifold.
There are plenty of fabricators out there making RB manifolds, and most are easy to talk to. Some will even make the manifold to the specs you want without having a cry...
DO YOU KNOW ANY REPUTABLE FABRICATORS OR HAS ANYONE HAD GOOD EXP WITH ANYONE IN THE PAST ?
Surely you meant to say wouldn't* run anything except a 6Boost?
hmm i hope kyle ups his customer service coz he's loosing from that.Anyway back on topic. would be interesting to see what the 6262 can do. Is it twin scroll. Still waiting on Dave's setup but, a brother has to pay his rent before messing with the car.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
