It's being built to circiut, 3deg camber on front and 2.5 rear
Nice im building mine for same application and ocasional strip run . I want to look more into setting upnfor camber I am putting the gk teck camber arms in rear any particular adivice on the way to set it up ? I know its prob wrong thread pm me if you want :)
Went to the drags tonight
Car weighed in at 1661kgs plus 108kgs for me
And with a less then Ideal run it ran 10.88 @ 132.23mph on 24psi and was politely asked to GTFO :)
Congrats Mick :) What was the 60'? And what tyres + size?
My R33 weighed 1760 with me in it (102kg) Didn't think they were that heavy!
Mine weighed in at 1580 kg. Only weight oust of it was wheel, jack and boot interior. Where is the extra weight coming from? 80 odd Kgs doesn't exactly hide under a seat.
Must be that fuel pump, Mick ;).
Thanks mate, Toyo TQs in 255/?/16s, haha I forgot the profile
1760 is about the same, mine is 1770 with my fat arse in it
9ltr surge tank and a 7kg pump, all new line with original ones still there, two amps and the woofers for the front splits are 5kgs each, RB30 half grout filled plus a heap of other, it all adds up :(
The R32 is either 1408 or 1480, can't remember
I too can't do without a good sound system, must be the wog coming out of me
  • Like 1
Have you tracked it with these settings yet? I'm at about 4deg front and 1.5deg rear. I think I need more at the front but have not really looked into the rear as much.
Mine is full interior but no stereo, hicas, air con or spare wheel/boot lining and weighs 1430ish kg without driver and 1/4 of a tank of fuel so there is a lot of scope for your car to lose some weight
I wouldn't think you'd want more than 1.5 degrees out back with over 400kw would you? It'd just be bake city every time you put your foot down.
It's a balance between grip in a straight line and grip in a corner, if you grip more in a corner you get on the straight going faster which means less chance of wheelspin.
In saying that, warm r-comps don't really spin at all in a straight line
Thanks Zebra
I'm a Kiwi and buggered if I'm going drive around with no tunes, so its not just a wog thing :)
I have but the tyres I had on it where crap, Faulken semi craps lol, these setting working pretty good with them, when I change the rear lower control arms I will knock it back to 2deg
The R34 is heavier then the 32 from the get go, and given it is suppose to be a street car I'm not to worried about weight, when I first bough it the old owner had completely striped it out and it weighed 1480kgs, I raced it the day after I brought it and weighed it then before putting it back together
Michael, I agree with what Simon said :)
I got a couple of kiwi mates, they think they're rappers when on the piss haha, top blokes though
Haha yeah that sounds about right, I'm from Irish heritage, so no rapping from me :D
Cheers Pete, load of fun getting it off the line :D, can't wait to try and get it out of a corner
What wheels were on the R34? I thought 16's wouldn't fit over the brakes on 33's and 34s?
I went 11.5@126 with a 1.81 sixty foot. Only mods were -5's and fuel + ECU upgrade making 327rwkw and 19" tyres.
How were you launching yours?
Factory R32 16s, with 20mm spacers and a quick grind off the ridge of the caliper and they fit with like .5mm clearance :D
I ran last week with 275/35/19s and couldn't get more then 128mph, the Toyos stand 1" lower in OD the the 19s I have, I have 265/35/18 hankook semis I have to get rims for and they are smaller in diameter again
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
