It's being built to circiut, 3deg camber on front and 2.5 rear
Nice im building mine for same application and ocasional strip run . I want to look more into setting upnfor camber I am putting the gk teck camber arms in rear any particular adivice on the way to set it up ? I know its prob wrong thread pm me if you want :)
Went to the drags tonight
Car weighed in at 1661kgs plus 108kgs for me
And with a less then Ideal run it ran 10.88 @ 132.23mph on 24psi and was politely asked to GTFO :)
Congrats Mick :) What was the 60'? And what tyres + size?
My R33 weighed 1760 with me in it (102kg) Didn't think they were that heavy!
Mine weighed in at 1580 kg. Only weight oust of it was wheel, jack and boot interior. Where is the extra weight coming from? 80 odd Kgs doesn't exactly hide under a seat.
Must be that fuel pump, Mick ;).
Thanks mate, Toyo TQs in 255/?/16s, haha I forgot the profile
1760 is about the same, mine is 1770 with my fat arse in it
9ltr surge tank and a 7kg pump, all new line with original ones still there, two amps and the woofers for the front splits are 5kgs each, RB30 half grout filled plus a heap of other, it all adds up :(
The R32 is either 1408 or 1480, can't remember
I too can't do without a good sound system, must be the wog coming out of me
  • Like 1
Have you tracked it with these settings yet? I'm at about 4deg front and 1.5deg rear. I think I need more at the front but have not really looked into the rear as much.
Mine is full interior but no stereo, hicas, air con or spare wheel/boot lining and weighs 1430ish kg without driver and 1/4 of a tank of fuel so there is a lot of scope for your car to lose some weight
I wouldn't think you'd want more than 1.5 degrees out back with over 400kw would you? It'd just be bake city every time you put your foot down.
It's a balance between grip in a straight line and grip in a corner, if you grip more in a corner you get on the straight going faster which means less chance of wheelspin.
In saying that, warm r-comps don't really spin at all in a straight line
Thanks Zebra
I'm a Kiwi and buggered if I'm going drive around with no tunes, so its not just a wog thing :)
I have but the tyres I had on it where crap, Faulken semi craps lol, these setting working pretty good with them, when I change the rear lower control arms I will knock it back to 2deg
The R34 is heavier then the 32 from the get go, and given it is suppose to be a street car I'm not to worried about weight, when I first bough it the old owner had completely striped it out and it weighed 1480kgs, I raced it the day after I brought it and weighed it then before putting it back together
Michael, I agree with what Simon said :)
I got a couple of kiwi mates, they think they're rappers when on the piss haha, top blokes though
Haha yeah that sounds about right, I'm from Irish heritage, so no rapping from me :D
Cheers Pete, load of fun getting it off the line :D, can't wait to try and get it out of a corner
What wheels were on the R34? I thought 16's wouldn't fit over the brakes on 33's and 34s?
I went 11.5@126 with a 1.81 sixty foot. Only mods were -5's and fuel + ECU upgrade making 327rwkw and 19" tyres.
How were you launching yours?
Factory R32 16s, with 20mm spacers and a quick grind off the ridge of the caliper and they fit with like .5mm clearance :D
I ran last week with 275/35/19s and couldn't get more then 128mph, the Toyos stand 1" lower in OD the the 19s I have, I have 265/35/18 hankook semis I have to get rims for and they are smaller in diameter again
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
