That was bound to happen considering it is a small turbo (especially hot side) for such a serious engine, same result with that other fella posting in the RB30 section.
I agree, I'm running a 6466 on my RB30 and I have not had the need to go over 6000rpm yet, on low boost. Turbo is well and truly whistling away by 2500rpm
  • Like 1
265/35R19
Can't even imagine how ridiculous GTRNUR 3.3l is to drive
I was seeing about 5lb at 2000 rpm and 18lb aroudn 3400 before it was tuned properly, so it it would probaby be even better than that now. Although now with the 10lb gate springs springs the gates bleed little until max boost is reached so it will be a little more laggy. Something I hope to have remedied soon.
I'm ~5-700 later than you. 2000 and above you can feel the turbo working. Great combo IMO.
I'm impressed with mine,yours would/will be/is next level again
3L+ and the 6466 is a killer combo.. Here's what I was seeing during some early road tuning of my setup... 3.4L, 6466, 1.0AR
26psi, 3600rpm loading it in 4th... will make 5 - 6psi instantly in any gear if the revs are over 2000rpm.
Do you have issues with fuel overheating on long drives of 2hours plus?
I drove mine for 2.5hrs trips 4 times in one weekend a month or so back with a Magnafuel Protuner 625 running a -8 feed and standard return lines, was no issues with heat
  • 1 month later...
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
