That was bound to happen considering it is a small turbo (especially hot side) for such a serious engine, same result with that other fella posting in the RB30 section.
I agree, I'm running a 6466 on my RB30 and I have not had the need to go over 6000rpm yet, on low boost. Turbo is well and truly whistling away by 2500rpm
  • Like 1
265/35R19
Can't even imagine how ridiculous GTRNUR 3.3l is to drive
I was seeing about 5lb at 2000 rpm and 18lb aroudn 3400 before it was tuned properly, so it it would probaby be even better than that now. Although now with the 10lb gate springs springs the gates bleed little until max boost is reached so it will be a little more laggy. Something I hope to have remedied soon.
I'm ~5-700 later than you. 2000 and above you can feel the turbo working. Great combo IMO.
I'm impressed with mine,yours would/will be/is next level again
3L+ and the 6466 is a killer combo.. Here's what I was seeing during some early road tuning of my setup... 3.4L, 6466, 1.0AR
26psi, 3600rpm loading it in 4th... will make 5 - 6psi instantly in any gear if the revs are over 2000rpm.
Do you have issues with fuel overheating on long drives of 2hours plus?
I drove mine for 2.5hrs trips 4 times in one weekend a month or so back with a Magnafuel Protuner 625 running a -8 feed and standard return lines, was no issues with heat
  • 1 month later...
