Not sure if you guys still wanna know as there's been a few posts on this thread!
This is also my first post [emoji39][emoji39][emoji39]
But this is my new cars set up (I haven't really changed anything yet - only enjoyed it so far!!)
R32 gtr
2.6
Built bottom end
33 gtr crank
Forged pistons, rods etc
Single trust t78-33d
Trust stainless manifold
Trust external gate and screamer
Custom camshafts... I was told they were "mild" but wouldn't mind finding out for myself as it's quite lumpy..?
Big trust fmic
Power FC
440lph pump
800cc injectors
3.5" Exhaust
Standard porting and plenum
He had it tuned at 366rwkw on 18psi
(Was still a fresh rebuild)
I have bought a water meth injection kit for it and am going to get retuned in August
With a bit more boost (and a better tuner) will hopefully make something around the 425awkw mark, but not too sure what the 800cc injectors will be good for?
R32 gtr
2.6
Built bottom end
33 gtr crank
Big trust fmic
Power FC
440lph pump
800cc injectors
3.5" Exhaust
800cc on 98, around 800hp
Stock Bottom End
Stock Plenum
HKS 1.2mm Metal Head Gasket
ARP Head Studs
HKS 272 Cams
HKS Cam Gears
T04z Turbo
6 Boost Manifold
4" Custom Dump & Front Pipe
3.5" Custom Exhaust
Sard fuel pressure regulator
Bosch Injectors 2000cc
Twin 255lph E85 Walbro fuel pumps
Splitfire Coilpacks
Greddy fuel rail
Greddy Oil Cooler
Greddy Front Mount Intercooler
Koyo Radiator
On United E85
1997 R33 series 2 Gtst
Forged rb25
Nitto rods
Cp Pistons
Power fc with z32
Proboost gtx3582 .82 rear
walbro 460lph
Need another fuel pump as I ran out of fuel pump and maybe relocate my afm near the throttle body.
How far can I push a gtx3582? Thinking to go Upto a 1.06 rear
Edited by Gta51
Forged rb25
Nitto rods
Cp Pistons
Power fc with z32
walbro 460lph
E85 or pulp?
  • 4 weeks later...
Forged rb25
Nitto rods
Cp Pistons
Power fc with z32
walbro 460lph
i pushed my gtx3582 with .82 rear to 500rwkw on a 30det e85
You, haha!
I don't think people should be surprised when they build a stroker engine/head combo, put a small exhaust side (turbocharger) on there and then the power noses over early... there will be more power earlier (more 'response') which is the intent of these builds but you just wont get that peak number.
http://www.sau.com.au/forums/topic/434910-rb3026-cam-selection/page-2
An elephant never forgets, lol
Hi Mike
Finally had the car tweaked and here are the results, same Turbo that was on the car with the last tune, changed the manifold , looks OK
98 pump @ 22psi = 437.3 awkw , E85 @ 22psi = 462.8awkw and E85 @ 25.5 psi = 475.7awkw
Tractive effort/torque is 974Nm peaking at 5250rpm
A good one to remember :thumbsup:
Hi Mike
Not the Turbo you told us that was on there. Mikes opinion was based on that.
No it isn't , BUT it is the Turbo that was on it when that Dyno tune was done when Mike commented on the way it reacted on the tune, it is the turbo that showed the result!
This Turbo was on the 2.6 before the build.I as told it was the 6262, never 6266 !
This is the Photo of the Turbo model when Jez took it off when doing the manifold, this was the news I was going to post at the end of the Educated Guess.
They said they put this on the car when doing 3.2 build BUT only after they saw that the manifold was off and the Turbo model would be noticed. They said I must have been pissed when they told me. It was never mentioned before or after , not once in all of the emails and other conversations I had with them, not once.
So whether or not it was on the 2.6 IT WAS ON THE 3.2 from the start and this is the Turbo Mike's opinion was based on judging from the Dyno Graph that was posted,
My long awaited RB34 dyno result, while it put me in the 400kw club I was hoping for more.
I believe valve spring float in top end caused by weak tomei springs, a reluctance to fiddle with the exhaust cam timing, and too small a hot side turbo housing prevented the top end from continuing to climb on the E85 higher boost levels.
The lower boost/98 octane tunes showed power climbing towards 8000. Not so in E85 due to the float issue.
Still, above 400kw from 4250 to 6500 makes it a mid range monster.
RB34 (3360cc, 90x89)
Tomei B Procams (10.25/272)
Full race twin scroll, twin 38mm gates, and a Precision 6466 CEA 1.0
E85
  • Like 2
E85
Awesome result. Midrange is insane! Can tell that it just wants more (just like the owner :) )
Whack better springs in + bigger turbine housing = 500kw
Do you think the rear housing is such an issue when Mitch's 3.4 pushes over 600kw with it?
Your right, its not a huge issue, but a larger housing and retarded exhaust cam would have delayed the impact of the valve float a little longer and seen more mid-top end gain.
Valve springs are my biggest issue. Paul went through the same thing with his 2.8.
Even with your current rev limit you'll be moving so quick.
What's springs are you looking at getting mate
E85 2000 cc inj
Twin bosch 044s and surge tank
Haltech platinum plug in
Gtx 35 1.06
Ported kelford cnc head
Tomei head gasket
Arp head studs
Kelford 272 274 10.85 lift cams
Rips stock bottem end with prep upgrade
Tomei oil pump
Rips 10l L sump and gredy oil cooler
426 kw at all 4
26 psi
Edited by danny14
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
