when i was using Caltex, they were bang on E70 the whole time (except for one batch in the dead of winter being bout E65)
which reminds me, i need to check with Caltex if they've switched to 85% - you could always buy a sensor, not run flex-fuel but just use it as a monitoring tool.
hahah, yeah that's true. just buy straight ethanol and mix yourself! :D
but for normal tunes, a variation of E% a few in either direction isn't going to make a difference. Don't think Trent has anything smaller than a 5% change resulting in any timing/fueling change on my maps
  • 5 weeks later...
The turbo is still 600hp rated though, now matter what CR you have.
The only way to make that power with a 35 frame is if it is a hybrid, like a 3566 or similar with a big A/R and judging by that dyno graph it would have to be because that is a laggy curve for a 35R on a 3L.
Even still, 500kw Thread: ACCESS DENIED.
It's a GTX53R not a normal GT35R so it does flow another 70odd hp more...
In saying that the results are a little eyebrow raising and also don't fit into this thread
Well last time you posted then 490rwkw result you only ran 136mph... :merli:
Time to go back to the strip and see if you'll actually get near 140mph, they be the results we wanna see
Either way it's not 500rwkw - so have moved the posts to the 400rwkw thread.
  • 1 month later...
car was making 431rwkw when i ran 10.8 @ 138 MPH
i have since gone to a new tuner and hence new results.
U know who micks motorsport is?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
