Haha firehose type 2000s.
I dont know why people bother with 1000's. Fark all difference in $$$'s and soooo much more room for moar powa with the 2000cc's. :P
Edited by Joshbigt62r
SS-4 Alpha ptotoype 1, Working with a 2.5L Rb25det and Tomei 264 / 8.9mm cams.
E85 fuel, externally gated.
This turbocharger made 465rwkws on 24psi maxing out 850cc injectors,
Thick yellow is from today, the rest is the controlled run. Ordered a set of 1200CCs, looking to crack 500rwkws.
It's now on 490rwkws. Same setup as above with 1200cc injectors. Vct is gone.
  • Like 1
On a hub dyno IIRC.
There isn't going to be 120kw difference between hub and wheels especially with the updated correction.
Sounds like they are not 1200s... what brand are they? Never heard of the flow being engraved into side before?
I initially went 1000s because years ago when I got them, I wanted pkug n pkay, and they were much cheaper then 2000s.
also, e85 was no where near readily available.
will be getting some next stage though.
Hey guys,
dropped my GTR in today to get the e85 tune.
Talked to the tuner and he said once you get up to 390kws + you have to replace all your fuel lines to much bigger lines?
Has anyone done this? what have you used and what is the cost involved?
Hey guys,
Man I have 1 044 in tank wallbro 600hp pump as a lift 2l surge tank with 2000id's I'm sitting just under 400kw.. Lines still standard to the filter.
Same, I made over 400awkw with standard lines as well...me when ppl give the wrong advice I understand that as we are not all experts, however, a mechanic / tuner 'should' know better
Cheers guys. As you said i only go by what so called experts tell me as im pretty much clueless myself.
But i do know my tuner is ULTRA conservative!
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
