Yeah the R3C is savage ( and has seen off half a dozen gearboxes ) but I've done about 40k kms in a few years and am impressed with its durability. For example: the other day I limiter launched twice in second thinking I was in Rwd but was in max 4wd . I reckon that would be enough to fry most clutches. I do agree the R3C isn't the right clutch for us, but in the right application ( not sure what that is ) I reckon it would be awesome.
Rb26
Eagle rods
Cp pistons
Tomei type b cams
Tomei gears
Mild head porting
Exh manifolds ported
Rotomaster 2860-5
2200cc injectors
120mm intercooler
Adaptronic ecu
Lc-1 wideband
Tomei dumps
Jim berry full Monty clutch
Apexi front pipe
100 cell cat
3.5" exh to x force cannon
B/c valve springs
Mac valve controlling boost via ecu
Best run of 360. On low but left it fat at 350 ish 19 psi
426 kw on 26 psi both united e85
Interestingly was 415 and we cracked airbox (std) and jumped to 426 so I will mod it. Another tuner said couldn't crack 400 with pump (walbro e85) and airbox or that I couldn't go over 24 psi on -5 guess he was wrong
Link to low boost run
  • Like 1
Rb26
Eagle rods
Cp pistons
Tomei type b cams
Tomei gears
Mild head porting
Rotomaster 2860-5
2200cc injectors
120mm intercooler
Adaptronic ecu
Lc-1 wideband
Tomei dumps
Apexi front pipe
100 cell cat
B/c valve springs
32 airbox always has been an issue. 33 on much better design, dual feed etc.
Good solid result. Be interested to see you go hit the 1/4! Too many '400rwkw -5' GTRs around at the moment that are failing to hit even 124mph let alone the 128-130 they should be, at least half a dozen now :/
10s gonna be EASY for you though me thinks, no fudge with your dessert! :thumbsup:
  • Like 1
I'm keeping the airbox but will modify the lower half and sheild the area where the snorkel was, I'm really concerned about traction even with semis although a bit hard she looses traction in 3rd gear on high boost, is this common with 400 plus Gtr ? Thanks for positive comments guys and thanks to jez for a job well done. I had a few issues he fixed , a restrictive tee piece, and failing alternator which actually makes a huge difference to tuning. Again jez is best, the flames are less common now but I'm glad I got a vid of it lol
It's really too bad my old Autronic SMC can't do flex fuel. I'm going to run a similar set up to Scott's with bigger cams. Change of fuel pump (and e85'n my system) would see 400's. So tempting but may have to wait for the next minor round of upgrades.
Great result there Scott! Really has me stoked for my build that will be similar -5 based set up.
It was good experience all said and done and jez is very patient although his initial words of he likes difficult cars came back to haunt with this puppy lol, jez do u rekon leave box for street and switch to pods at track? Wish I bought them with me for testing bugger.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
