Also I would ask the scrutineers at the drags what you will need when you get into the 10's, if I remember right you will need to fit a tail shaft loop, I got one but never fitted it.
You can have the one I got if you want it, it will need some mods to fit but its new and to spec and has all the nuts and bolts needed, you would just need some plate for the interior side, my new project is a MX5 that I will set up for the track and it will never need it (it doesn't have the torque to pull the skin of custard).
Theres also the possibility the ATTESSA hasn't been properly bled meaning it'll be more or less RWD… Just a thought that is. I bled mine up after changing to my old twin plate and it made a world of difference.
If the gearbox has come out at any stage the ATTESSA needs to be bled
Unless its got issues thats not normally the case. Every GTR box i pulled out went back together fine, and trust me i did heaps ;)
What you can do as a cheap mod is pull the plate out of the transfer case that the line goes into. Drill and tap a hole and put a bolt in it with a locking nut on it. Spin it in a bit to preload the trasfer case. I wouldnt drive around with it locked up very tight as you will probably wear it out but it would be fine for the drags :)
As for getting your car down the dragstrip sime1, what rpm is it crossing the line at and in what gear? What 60 footer does it run and is it spinning or bogging?
I had issues trapping at much more than 128mph and did a diff gear change and now run 136mph pretty regularly. Car weighs in at 1460 and was only making 420rwkw on the Advan dyno till the turbo change.
Depending on what the cars doing there are also some very cheap mods that can be done to help traction. Some washers is all it took for me to go from wheel spinning to bogging down pretty badly. You could also ask Yavuz to set up the 2 step on the Link, from memory it is running a Link isnt it?
ATR43SS4CBB Alpha turbocharger
93 model R33 GTST Forgied CP pistons, valve springs
Stock Cams
1200cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
4inch intake pipe
Adaptronic Plugin
Power 435rwkws @ 25psi , E85 Fuel
  • Like 1
Guided at 4000 / 4500 / 5000RPMs.
Per description on the boost curve sheet: 19psi @ 4079RPMs, 25psi @ 4218.
There was a split silicon hose that was unnoticed, affecting boost response. This turbocharger is going back to dyno again in two weeks time using my modified stock exhaust manifold expecting to hit full boost by 4000RPMs. It drives reasonably well on road, has a 3582's top end without the lag.
  • Like 1
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
