Congrats and good to see u are still waving the GTRS flag :)
-10s on my 26/30 was a weapon. Great combo imo!
Good to see a result mick!!!
Thanks guys, it only been 2 1/2 years coming :unsure:
I quite like the RSs on the 3.0, there's good drive down low and they push all the way to 8k :yes: makes it nice to drive and gives it plenty of punch when asked
needs more big single Mick :P
ah yes and we know you know all about big singles :domokun:
How much torque were you making . At 623 hp .
I have a 3582r going on mine kford doing my head interesting results on ya cam choice .must be very responsive I would like to know he ideal lift and duration who is making your custom cams I miggt get kelford to grind me some custom ones but knowing the spec would be great
IIRC it was about 800nm @ about 5200rpm
the cams I am hoping to get done are going to be hard on the valve train and since I have a few cars it doesn't matter if it sits around for a bit here and there, for a every day car Pauls ones from Unigroup are what I recommend, 260 x 10.8, this I have already posted in your thread
I went from 260 x 9.15 lift back to 250 x 9.15 lift on the old 2.6 and it made the same peak power just 800rpm sooner
Cheers I hope these soecs will do me well on track aswell on e85. I will talk to kelford see if they can do a custom grind
When you say will be hard on ya valve train is that because of such a big lift
How fasts the valve accelerates and decelerates. You need a firmer spring to keen the bucket on the lobe... That causes wear.
Who cares! Change them when they wear. Give me powah!!!
How fasts the valve accelerates and decelerates. You need a firmer spring to keep the bucket on the lobe... That causes wear.
bugger, you beat me to it
the other thing that concerns me is the belt, it is basically a rubber band after all, and yes, all in the name of powah and going fast
The rubber band.
Yeah. I know HKS say on their vcam the belt needs to be changed every 10,000 kms.
Being a jap cam it would be soft as a pensioners turd but the acceleration (and load on the belt as the intake cam retards with revs) would be significant.
R34 GTR
593awhp/445awkw @ 24-25psi
RB26/30DETT
HKS GT-RSs, yes fancy -10s
250 x 9.15 poncams
ARC cooler
ID1300s
custom twin 3" into single 4" exhaust
Syvecs S8 ecu
has done 623awhp/467awkw @ 28psi
congrats on the results
any feedback on the ID1300 injectors?
R34 GTR
RB26/30DETT
250 x 9.15 poncams
ARC cooler
ID1300s
Syvecs S8 ecu
Went to the drags tonight
Car weighed in at 1661kgs plus 108kgs for me
And with a less then Ideal run it ran 10.88 @ 132.23mph on 24psi and was politely asked to GTFO :)
  • Like 3
Nice one do you normally drag it or cicuit ?
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
