Nice result Ant eater. So much for not running more than 20 psi hey ;).
How does it feel?
not sure yet Paulie
haven't had the chance to use those 600 ponies just yet
but QLD SAU drag day next weekend - I think I will open it up a little
they tried 30psi but them stock springs don't like it lol
Are u gonna change your springs ants.. After my last engine failure I'll never use stock or jap springs again
yeah, eventually I will mate
Your previous engine died because of the OEM springs?
Yea they were either oem or tomei mate. Can't remember exactly but they were soft and only pushing tomei cams
ended up breaking in 3 pieces and smashing itself into a forged piston, around 20,000 old so shouldn't have failed
what did you replace them with?
awesome result ants :)
call me soft but i dont drive mine on high boost which is 430kw at i think @ 25psi (i need another 044 pump run higher than e55 mixed blend & higher boost)
just take it easy mate - its a lot of power (fark im getting old)
Ferrea dual springs with locks and retainers., haven't actually started the engine yet but the builder reckons they re the best and the fitment of the components is excellent
sweet will look into that
thanks Marko
Having a really decent fuel system is key to the HP thats for sure
You only live once - boost that shit up Marko
Hi Joey, this is what I was taking about earlier about the UE springs ??
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
