There is no overkill with these things Paul, sick of shit breaking
All up it was 1200 delivered from the US pete.. Dual springs, locks, seats and titanium retainers
Sounds impressive, I was reading that duel springs "can" save you some problems if one of the 2 springs breaks and can save you some grief.
Mine around 900 so I guess they should do the job, well working on "you get what you pay for" and the fact that they will not get thrashed, well :rolleyes:
I would imagine I should be around 400awkw ish after the build and I wont have to sneak on the thread, if not I will touch up the Graph, :pirate: haha
  • Like 1
I would be very concerned if you didn't make 400!!
So would I Nick BUT I just want it where "I" can use it and not sure if I am going to add another fuel pump and maybe a surge tank, I have a Walbro 460lph on now, it takes it hard to 9.5k limiter and if I can get the car to be responsive without driving around @ 3- 4000rpm I will be happy. I know the response is only a gear change or 2 away, but I want to be able to drive it in 6th gear at 60kph but I am not sure how much the build will give me down low??? :no:
Really as a DD it has as much grunt than I really need, well :whistling: , but I want the extra torque from the 3.2Lt stroker build, plus the drivability from the coppermix twin clutch. I have to say since the last work the OS Quad clutch is not a major problem, could be better in traffic.
Now for the brakes, they are Brembos (gold) but are crappy and I would not bet my life on them. It has been suggested the Endless CCRG pads are very good and some quality fluid, what would you recommend?
Yea get the endless pads.. Either the ones suggested or MX72's pete.
Don't get too caught up in the fluid mate, any DOT 4 is fine..it's not a race car.. Just make sure they give it a good flush through when they change it
how much power are u making & is your walbro supporting your power or is it touch & go?
Thanks Joey, now off to work you go :action-smiley-069:by the way if your car is not running, no 400 anything, I think you and Paul sold your cars a few years ago, haha
I am going to do the brakes before the build or the final tune, there is a good bloke up here that can look after that and I will be seeing him today.
Seriously, as for it being a 400kw thread, I cannot think of a better thread to get the advice I need to be able to get the car into the 400kw club, than talk to you blokes :wub:
Hi Marko, it is 345.4awkw modified and tuned for response, it has a worked motor, forged pistons,oil,water etc with enough mods to go for more HP as it is, would have to change turbo and cams, but I want it down low, not peaky.
FUEL, I have taken it to the 9.5k limiter without a fuel problem. It does not seem to have the same grunt as when first tuned,I think my plugs are now blackened up going on the shxt it blows out the back when you start, rich as !
Thanks guys and sorry for butting in :yes::no::yes::no::whoops:
what seems to astonish me is that you are gonna have all the cubes under your belt (3.2lt engine) and with a turbo the size of an Island and you appear to be concerned / insecure about making 400kw???
I think you need to look closer at the 500kw threshold bud
haha, I am not insecure about making the KWs, I do not care, I just want it to drive the way I like a car to drive and if my new mods and tuning for response works I do not care if it is 399.9 or 501kw.
I do not think a PT6262 would be considered a BIG SINGLE, I took off a bigger one because it was a laggy heap of crap :yucky:
My mistake was buying it in the first place( just looked so good) and believing all of the hype and the bullshit from the seller for these R34GTRs :yucky:
BUT the longer I owned it and with a couple of mods I started to like it, now I love the bloody thing and will do what I have to to get the results I am after. :wub:
I do not think this is any different from any of you blokes on the SAU, all good as long as you get what "you want" from your car :yes:
Hi Tricstar, here is the Dyno 345.4Kw, on 98pump, tuned for response if that makes a difference. The 337.9kw is with the old T78 when I bought the car.
everyone says it should be a lot more and I expected about 260 ish but I was happy with the result, the car is much better to drive now. It will be interesting to see what I get after the stroker build
  • 4 weeks later...
VG30DETT
Full house -Jun 264/9.5 (circuit spec)
ID1300CC
GT2860RS (-5) (17psi actuators)
98 fuel
16psi.....400.1rwkw
22psi -21psi ......442rwkw
E85
18psi ....435-440rwkw
19psi ....448rwkw
24psi ....478rwkw
27-24psi .....492rwkw (new record?)
at 4500rpm ............... 840NM TORQUE and virtually 400rwkw
took EBC to 100% and it went over 30psi at 4400rpm ..And was shut down at 4700rpm .
the dyno map sensor only reads to 30psi so it just started to flat line the results on the graph .
it was at
410rwkw at 4500rpm
429.7 rwkw at 4700rpm
but surging!
  • Like 1
I've always liked the xr6 turbo BUT there is a trade off... my mate made 390kw with his and blew many transmissions, diffs and uni joints. What a torque monster though
Drop that donk in a gtr (only if) = win :)
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
