I've always liked the xr6 turbo BUT there is a trade off... my mate made 390kw with his and blew many transmissions, diffs and uni joints. What a torque monster though
Drop that donk in a gtr (only if) = win :)
The BF and FG will make >400rwkw with the stock turbo, exhaust, diff and gearbox all day everyday, the BAs won't handle more than 250 before blowing both of them up though.
Haha, I to thought about putting the Barra motor in a GTR and the adaptor plate wasn't really an issue, the hieght of the 4.0 on the otherhand with the 4WD sump will pose a few issues :(
You would definitely need a massive bonnet bulge to fit it in, quite a tall motor.
I made 300kw in my BA when everything was pretty much standard. Gearbox and diff lasted less than a month haha. I guess that's what you get with 1000 odd NM.
PS: An FG XR6 won't make 400kw with a standard turbo but the F6 will.
  • 6 months later...
Racepace built rb26
PTE 6262 twin scroll setup
6boost manifold
Stock cams
Id1000's
E85 + twin intank Walbro's
Power FC
This was on 23psi
probably a bit more boost in her too
Do you have an RPM graph for the X axis?
would love see what rpm boost and power is made
Good thread revival Buraz!
How did u squeeze 2 intank walbros? Do u have 32,33 or 34?
It's an R33 Gtr, Racepace did all the fab work and all the fuel setup. I couldn't exactly tell you what adapters etc they used, i didn't see it all while outside the car. I know they made it all in house and there was lots of work involved.
This is the only graph I have!!
Probably is but didn't want to push it, engine has lots of track days and kms on it since rebuild I just wanna keep it safe until I have it freshened up.
Even with a Nitto 3.2 I could not make it :no:
But have not given up just yet :unsure: this was 98 pump
Going to upgrade the fuel line and exhaust. Do a flex tune , should make it on 98 and then see what E85 does to the Graph ????
  • Like 1
Racepace built rb26
6boost manifold
Stock cams
Id1000's
Power FC
This was on 23psi
What AFMs are you using there?
everyone in this thread good at changing boxes?
I'm up to 4 broken after doing 2 in a weekend at Racewars not long ago
So far I've stripped 3rd gear twice, sheared the input shaft once and the latest appears to be a broken reverse/5th selector fork.
In saying that they only ever break when no mechanical sympathy is shown, if you are gentle and select the gear and the roll off the clutch they seem to be fine (as oppose to smashing through gears and kicking clutches)
Edited by SimonR32
make well over 400 man.
Apart from the problems I have had since the build it goes pretty quick now , very linear. Feels great on corners, no surprises/
It will be interesting to see how a bigger Dump and Cat makes it respond and what it adds to the overall performance :/
It will make a more then noticeable difference pete
Hi Joey, hope your right, hate wasting money.
There seems to be 2 different opinions on this subject but I am going with what you blokes have told me from your experience as I like first hand feedback not from books:)
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
