Apart from the problems I have had since the build it goes pretty quick now , very linear. Feels great on corners, no surprises/
It will be interesting to see how a bigger Dump and Cat makes it respond and what it adds to the overall performance :/
Let's not turn yet another thread into a discussion about your car, please.
  • Like 7
My setup is currently making 450kw @24/25psi with a 6266 and built 2.6
Next step is fuel pumps upgrade/lines/rail and reg and keep pushing till turbo has no more left, were thinking around 32-35psi and 550kw ish
Edited by SiR_RB
  • Like 1
For the life of me could not think of a nice way to say this.
Buraz, show a pic of your setup. Have you taken it down the 1/4?
haha, I understand what he is saying and take no offense, he is right :)
But as this will be happening soon I do not know any other way of getting to the facts , as I get told a heap of shit and do not know where else to get the answers.
This thread has the blokes that have been doing this for a long time and I got the answer I was after, DONE!
  • Like 1
I didn't know the 6466 would stretch that far on a complete set up. 550kw sounds absolutely mental
just out of curiosity, RPM wise whereabouts does boost begin to build on the 26?
