http://www.anfittingsdirect.com/index.php?...1b11a2817fc507d
Whoever's fuel system that is in the picture- You have to be very carefull putting hose clamps on pushlock hose/fittings.... it will cut the inside if the hose and lift the hose off the barbs either side of the clamp.... it's more likely to leak putting the hose clamp on!
It's not cheap, but aeroquip starlight hose and fittings have been designed for all sorts of ethanol/race fuels... awsome stuff!
Cheers
Justin
The silly old man did the clamps on the hose thing. I have already removed them and will shove them up his ass at the earlieast opportunity.
just what i was gonna say, bosch do them @ 12v not 14
also you other blokes like marko, you sure you are not getting confused with 040 & 044?
sometimes people do that :P
"Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI"
...straight off this website: http://www.boschfuelpumps.com/
thats a company website trying to sell pumps... they have written that information themselves, and it contradicts the numbers provided by bosch on their website (www.bosch.com.au)
They look stainless..... they're gonna hurt- sharp edges and all! ha ha ha
http://www.bosch.com.au/content/language1/...s/fuelpumps.pdf
On the bosch website.....but yes as stated above at 12v
I would expect around 220 (maaaaaybe 240Lph) at 14V
Sounds about right, assuming that flow/voltage are fairly directly proportional you are looking at 245l/hr at 5bar.
I would say most street cars are running about 1.5bar plus 3bar base so would push flow up to 260l/hr... So enough to feed 720cc injectors :P
u are right just had a look - shouldnt always believe what i read :P
Even if it were true marko i would still take the pierburg on noise factor alone. You can hardly hear these things, unlike the swarm of hornets unleashed every time you turn the bosch on.
i luv that sound, like having squealing race brakes or BIG cams :P
My 044 mounted in the tank only ever makes an audible sound when priming...otherwise you can hardly hear it while the car's running
your ecu will have the factory fuel pump controler enabled, so below ~1500rpm the fuel pump voltage/current drops to keep noise down, turn it off and you will be able to hear it again.
You're starting to sound like an old man
"Turn that down you young hooligans"
lol
Thats right, when i had one 044 intank you could hear it but it wasnt as bad as people make it out to be...
...the 2 hanging under the car are a different story
lol
Sound like one? He frickin is one!
Oh and I forgot to mention the Pierburg pumps are a pull/push pump so no prime pump required if you don't need a surge tank
Ah internet sarcasm strikes again lol
The old man stole my seat at superlap and i didnt have the guts to tell off a pensioner :)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
