The only boost control device you need is your right foot :P
THIS.
I can't understand why people have those two stage boost controllers. i.e. 12psi low boost, 20psi high boost.
Pointless, if you want less boost, lift your foot a little??
My factory boost controller has been modified to give up to 13-14 psi, I have a switch turning it on and off. Boost gauge doesn't like regular changes though.
Clutch slippage, low boost till fixed. (done)
Coilpacks going, low boost till fixed. (done)
L plater girlfriend driving, low boost.
Car feels different, still nice to drive just a bit slower, I actually preferred it for a while.
Traction on nankangs is poor, esp in the wet, low boost helps as the stock turbo is insanely responsive and quickly goes from 7-14psi, wheelspin. Also with stock turbo there really isn't much difference between 7 and 14psi in terms of right foot position, just in power. The boost curve is weird because I don't have an electronic boost controller. 7 psi by 3000rpm, 14psi by 3100rpm.
Not sure why you'd do it with an actual boost controller. I did it to help the turbo, and the above reasons.
It's not going slower I was after, it was less boost, less engine stress. I preferred the switch.
Edited by Galois
It will have grip Steve. the tyres on it atm are just some nankangs that we use for the dyno
Track spec is going to be something entirely different.
I have to give credit to Marty White for the job he did on the head. It looks like bugger all but as he said, watch it spool. And boy! does it spool.
I had nankangs on mine for the tune and they turned to smoke and sprayed rubber up the wall and onto the roof of the car. lol
It looks like I'll get to the 5's just as you're getting to the 4's. Have you decided on turbo?
If you get into the 5s it will be on a boost level you wouldnt use everyday.
As for the turbo, it has become a very hard decision now. There are sooo many i want to try. There is one combo i would like but it means a total re-engineering of the exhaust side of the engine and im chomping at the bit as it is to get the thing on the road.
Lol, I'm not one of those high boost low boost switching people. Set it once then leave it, I figure it's not like the car runs at the highest boost all the time, only full throttle and that's up to my right foot to control :D
The 5557 sounds like it could be the winner for you from what powertune have done so far. I know what you mean about trying heaps of setups-that's all I talk about with Tonys brother every weekend......now where did I leave that money tree....
Steve, the 5557 i think is GT3076 territory.
One of the options was a Precision turbo though.
Believe it or not i am already planning the next engine turbo combo and the current one is not even finished yet :D
I'm hoping to have a stock rb25det/5557 plain bearing result veeery soon.
400 would be nice.... ha ha ha at the fly.
400......hp :D
Likewise, as you know.
I've got the bug bigtime to drive it again
nice result noel you crusty old man. although it really is way too much power just to drive to bingo on sundays but I guess you can get there early for prime seating. :D
hehe. seriously though that's a kick ass looking set-up mate. hope it gives solid service for years to come. :P
THIS.
only reason i like having diffrent boost setings is so when i go to the track i can put my car on 16psi instead of thrashing it on 19psi all day long.
It didnt :D turbo number 4 shat its self on saturday
Yeah we are removing it now to send it off to Garrett to find out why. The last 3 turbos all failed for legitimate reasons. I'm expecting this one to be the same. It's a damn shame but we'll see what they say. Considering he's got sonic stickers all over the car I hope they give him a free one. If not then I'm sure he'll move to turbonetics or something journal based. He certainly doesn't need to worry about response
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
