I guess its better to have head room HP wise, you could run less boost and more timing and make the same power with less strain?
Not always more timing as it's not really being limited by the boost at the moment. I think we are going to have to really sit down and consider all options. It's fair to say we have found the limit of this turbo. Hopefully knowing a benchmark will be all we need to move forward productively
I actually meant to say less timing, sorry typed this while getting earbashed on the phone at work lol, I guess what i was trying to say was milder tune less boost on a the bigger turbo you were mentioning for about the power the old fella wants!
well from what we can gather:
3L bottom end + GT3582R with 0.82A/R rear housing
750deg runner temps but possibly exceeding 950 degrees in the housing due to the size restriction. The bearing cage and everything around it was blue all the way to the comp side apparently.
Considering an offer from Garrett but if he moves to the BW turbos it will be a 0.92A/R but better than that it will be a T4 footprint which means more gas flow and less heat. Unfortunately it means more hp which we don't want
I hope this stays well documented.
My brother is on his 2nd 3076 for the same reason. At 18 psi the .63 rear gets white hot on a 2.6L 4 pot.
Can I suggest if a 35R stays on the motor a re-profiled HKS 1.01 rear housing be considered? It is a 3037 housing yet as we all know all 35R housings are simply reprofiled 30R housings to begin with. The HKS housing should open it up as much as necessary without much loss in response, it will also be a bolt on affair as far as the manifold goes (save some $$).
For the tracks we race on in QLD, anywhere between 500-600hp is ideal. Actually its more like 550hp would be the max you would want. Anything north of that in a gtst is just time robbing.
anything over 400hp in rwd is a handful
Yeah I thought that's what you may have meant. That's pretty much the idea he had also
You can suggest it but I can tell you what Noel will tell me if I forward that suggestion:
gof**kyaself - followed by a beating with a barbed wire stick
We don't want to take any chances, the 1.06 rear MAY.....and I mean MAY be ok but Noel has made it quite clear that he does not want to do this next one on a maybe. He's been through too much already for me to make anything but absolute decisions.
If we go back to a Garrett turbo it will be the GT3788R. This turbo made more hp than the T04Z and came on sooner by about 3-400rpm which is only a tiny bit laggier than the 35R but with the 4088 comp wheel it flows way more air. The housing is a T4 so gas restriction is at a minimum.
It's either that or the Borg Warner turbo of equivalent size which has a tougher bearing assembly, billet comp wheel, turbine capable of higher temps and comes with provision for wheel speed sensor, had a built in recirc valve and is internally gated (yes it's a large gate and has been proven to work at high volume)
I am personally worried about swapping to an unknown device (as in unknown to myself) but we still aren't ruling out Garretts option
I dont understand this the 0.82 housing on the GT35 cannot survive the amount of power and therefore overheats. Your initial comment of not wanting any more hp but then saying that if you stayed with Garrett you would choose a larger turbo. Why would you not choose the 1.06 housing on the GT35 for a slight increase in lag but very similar hp and hopefully some reuse of turbo parts with your current blown turbo??
It would have to be THE most common aftermarket turbo used on an RB30 block.
It's not the power that creates the overheat, it's the restriction. And can you 100% guarantee that the 1.06 rear housing will be enough for him? Give him a guarantee and I'm sure he'll hold you to it.
The fact is that we THINK the 1.06 will be enough but it's not good enough to think it will. We have to know it will.
So if there are ppl who are making 550hp at the wheels on a 1.06 rear running 24psi and can give us turbine housing temps and comp wheel speeds, then I would love to hear from them
Unfortunately the kind of people who would have data for you are the ones least likely to share it.
Well power=flow and it is the flow thats causing the overheat. A particular size housing will only be able to flow X amount of air at a reasonable temp.
What do you mean will the rear housing be enough for him?? I thought you didnt want anymore power?
Surely Garrett can supply this information to you? I have attached a plot from the Garrett site comparing the different exhaust housings. Seems to be a significant difference in flow capability between the 0.82 and 1.06.
I would be also reading through the thread below and pm'ing all the guys with the 1.06 rear housing:
http://www.skylinesaustralia.com/forums/Gt...l=T04Z+database
If not enough info here the vl boys on calaisturbo would most likely be able to help.
What I mean is will the 1.06 housing be enough to drop the temps. Consider this. What if the EGT's exceeded 1000degrees momentarily? Will the 1.06 rear be enough to drop that momentary heat rise to below 850?
We spoke to Garrett in length and their answer was basically this:
We give this charts based on standard vehicles. Noel's engine would be exceeding 100% efficiency. We cannot give accurate guidlines on turbine housing selection or turbo selection on heavily modified engines.
......Yes I did think wtf.
If we swap to a 1.06, what if the housing temps get to 900? They are only rated to 900. It is too close for us to play around with it. I think also that the E85 MAY have something to do with the heat rise also. We are in fairly unchartered waters here with this new fuel and even though logically it shouldn't, I think it is having that added effect.
The V8 supercar guys are having more trouble with engines blowing since the change to E85 than ever before. This is straight from their own mouths. And they believe it is due to the extra heat it is inducing.
I don't know the technical details behind it but I am going to do more research and find out
Quick browse through calaisturbo and number 7 and 8 on the 1/4 mile list in QLD run GT35s:
#7 OVL087 - 9.95 @ 137mph ............. 27psi gt35 , glide , roo16
#8 Exchaser - 10.09 @133mph ............. RB30, GT35, mt et streets ,31psi E85, keas 3 speed
From the look of that 31psi and e85 seems to me that the 1.06 will drop temps that much.
Yeah point taken its not a direct comparison but I understand the car we are talking about hasnt been doing laps and laps to bust the turbo either? Did it make it off the dyno?
Personally I think 20-22psi through a 1.06 housing will bring the temps down enough but I am not going to pay if it doesnt so I will be quiet.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
