ive seen them go over 10500rpm constantly and never had a problem with them. I personally have ran them over 9500rpm nearly everytime i start my race engine and they free length and compession tested like new items on strip down.
something a bit more enlightening than saying something is shit would be appreciated.
maybe sometimes items are only as good as the way they are set-up/assembled
yeh my bad
drop them in out of the box (the way jun make them to be) they have too little seat tention. but then i guess if they were 'setup' aka made to work properly, theyd do the job.
in a big $$ head i dont like using parts that need to be made to fit/work, id rather use a part that out of the box works perfectly
yeh my bad
like my new favorites...you know the ones...the double ones.
does anyone in this topic make decent power @ 4000 rpm?
according to tyndago's (probably old) spreadsheet, boosted to the max, stock is
good for 250hp @ 4000rpm atw .. that is 180kw.
So I'm wondering if anyone close to 400kw can show 180kw at 4000rpm, or to look
at it another way, sees 1bar at or not long past 4000rpm ..
Street driving unless you're after a speed ticket or a noise violation I think is spent
mostly 1000-4000 rpm, I just spent an hour crossing sydney and despite consciously
trying, I found maybe two opportunities to hit 5000rpm without looking & feeling
like a tool. Ok maybe I look like a tool all the time, but you know what I mean. Street
it is mostly about 4000rpm.
Ill be able to say an accurate dyno figure very soon, get the car back in the next few days. Built 3L bottom, 270 cams, mild porting, ARC cooler, tomei dumps, hks exhaust, GTRS's on 2 bar.
Only thing left to do is add another fuel pump (only got one 044 intank) so thats holding it back
Ill be VERY suprised if it isnt making decent power @ 4000rpm. Gotta love the RB30 :P
Here is a dyno plot from a RIPS RB30DET setup running a Garrett T04Z that passes 180kw @ wheels before 4000rpm, definitely the most insane power delivery of any GTR I have been in. The dyno plot does it no justice, it feels like it pulls HARD from absolutely any revs - its nothing short of nuts.
thats pretty awsome..
oh and with the springs its not all about seat pressure :P
and paul/brad i was going to just blend the intake squish band to favour the exhaust.... but i decided to blend them both. and i do know a thing or two about engines.... r and d = common sence.
cheeres.
ps. as far as i was aware all cams over 10mm have a 29mm base circle?
cheeres.
yes
and yes
yes again
cheers to you
and also no JUN 10.5's and 10.8's (272's) are 30mm and also their 10.8 280's...the Tomei 10.8's we use are 30mm base also.
Edited by DiRTgarage
cheeres.
In no way doubting you Dave, didn't know if you did your own heads or gave them to someone else.
Is the head coming back off to do this or is it ready to drop 10mm+ cams in and go??
Edited by Risking
A good read in this thread, its really interesting to see how many different combo's there are making this power, different totally different setup's, and they are all different in there own way.
GREAT THREAD.....
There not skyline's still skyline motor's.
Sean's VL calais, RB30 with modified RB20 wiring loam and nistune
Full built engine, rods, piston's headwork ect, you know the drill
T04z
6BOOST manifold
48 progate
JD custon intake with ported runner's
Our own custom fuel setup's
3 1/2 exhaust
Full manual 4speed jatco, 4200 stall
518hp on 24psi pump.
My own VL calais
Full built, you know the drill, but $2500 on the head and cam, spec's custom.
6BOOST manifold
progate 48
35/40 1.06 rear
Rajab inlet with ported runner's
Our own custom setup fuel system's
Autronic Smc with dis4 MSD
Full built jatco with 3200 stall
Still on baby tune as we are moving shop and awaiting our mainline dyno mid feb, should see 480hp. (finger's crossed)
Edited by EFI Performance
yes! that is the point. good to see diferant combos. ps. if you havent caught it yet i cant stand "black art" engine specs... each to there own i spose :P
Black art???
What's that, hidden spec's or is that not aimed at me??
428rwkw
standard stroke rb26
garrett t04z on 6-boobs (24psi)
jun 272 10.5deg cams
the jun cams are carnts because of the base circle adjustment, it i was to do again hks 272 10.2 or tomei 270 10.2 would be used!!!
wat size rear housing did u use mate?
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
