  • 3 months later...
Theread revival time. back on the dyno yesterday for some preliminary work and promptly spat out 450 hp at 13 lb.Serious time gets serious next week.
I think I'm gonna love the new turbo.
Time for some big power Noel! Keep us updated.
Whats the setup again?
I can't remember... Perhaps I'm getting old? :rolleyes:
Absolutely not. The aim is for same power but more reliable at those power levels
GT3788R, RB2530, Wolf V500, E85, Bosch Black 1600cc injectors etc etc.
Boost response on the 3788 is virtually identical to his 35R. The lines literally trace each other
Very interesting to hear about the GT3788Rs being that good, I had wondered (thinking the GT40 turbine was a bit overkill on the GT4088R for a "small" motor")... Look forward to hearing the final results, sounds promising!
Wonder why those turbos aren't more popular, they've been around a while now.
They have been super popular. New turbo design. They are only about 1 year old technology now.....well, to retail
This thing sees 20psi before 4k - approx 3800-3900
Not many results around would be the main thing.
Ive always looked at them as an alternate to a T04Z but too hard to find meaningfull results
From what we heard before we put one on Gervase's 33GTR, the XR6 guys were replacing Z's with them and gaining about 100hp at the wheels and 400-500rpm better response
Gervase took off his 0.84 T04Z and put on the 0.89 GT3788 and gained about 400rpm response and made (I think) about 80hp at the wheels more on the same dyno.
This is the 4th one of these turbos I have fitted now, every single one is as responsive as a 35R or around the same but makes 150 odd HP more at the wheels depending on the application of course (mostly 25/30's or heavily modded 26's)
Is that including going from a single entry GT3582R to a twin scroll GT3788R? They've been around for quite a while, I think I gave up on looking for results for them over a year ago - so if there have been a bunch in the last year - that explains that. Looking forward to seeing the final tune results for this!
CAR: nissan stagea 260rs
engine: RB28
engine mods:
N1 block
full hks step 3 stroker kit (crank, rods pistons)
garret gtx4294r turbo
tial 60mm external gate with screamer pipe
hks gaskets
hks timing belt
hks cam gears
hks fuel rail
hks 1000cc injectors
hks oil pump
n1 water pump
trust sump kit
tomei 280 degree 11.5mm lift drag cams
tomei drag valve kit
tomei titanium retainers
tomei valve lifters
race cut valves
race valve guides
arp head and main stud kit
trust PEII 3" exhaust
koyo race radiator
100mm intercooler
2x walbro 255 fuel pumps
sard FPR
POWER:
have to change exhaust so power is "restriced" to:
580hp@18psi on BP98
710hp@23psi on 109 race fuel
Correct Lith, it is a twin scroll setup. I keep looking up sleeves for hidden cards but at this stage it is showing remarkedly similar boost characteristics to the 35r single entry. Its only running gate spring pressure at this stage but until the gate starts open on spring pressure the curve is identical.
Waiting on a wide band sensor to arrive and then we'll hook the boost control up and go to town on it.
Pretty happy budgie so far.
Interesting indeed.
On dyno/loaded/4th i take it?
Any ETA on that? Surely it cant take long
