That run was an 11.1, not bad for 320awkw huh!
If I crossed the finish line in 4th and not in 3rd on the limiter, I would have cracked a high ten...oh well, I still talk about it 3 years later
130mph is fairly fast for the top of 3rd gear with 4.11 ratios (unless you have some funky long 3rd gear ratio in the box or revving motor fairly hard)
I have the same diff ratio, revving to 8100rpm and was in 4th for a fair while and ran 132.5mph
Also with a 1.5 60ft and 130mph you should be looking at least a 10.5 or quicker (something doesn't add up at all)
Edited by SimonR32
Mmm true that, 130mph is ~200km/h which is ~7000rpm in 4th with 4.11 and a GTR Box. Can't tell the exact instruments are probably out a little, but its around that range either way
I know cause i tested it out for N1GTR out of interest for the 1000M thing later in the year.
0.4 isnt too bad, i think the new cars are down under the 0.3s, but the old cars were closer to 1, i think i remember watching on top gear they claimed the veyron required 250hp to get to 150mph and an extra 750hp to get the extra 100mph, id say you would be surprised how much power is required to overcome wind resistance at 130mph
All the speedos I've looked at are out by up to 10% at those speeds, wouldn't be suprised if the tacho was also out, always over reading.
Edited by Rolls
that thing is a light switch... must be fun though
a ute with 400rwkw... umm better buy shares in a tyre company!... might want to invest in Bonds as well... free lifetime supply of underwear
It's heaps of fun, had powercruise on saturday, the car went perfect, had the best day out at the track.
Going to run it on Wed night at willowbank and go for a mid 10, then get the boot from the officials!
It has nothing to do with the fact it is turbo or v8, the reason they have different speeds is turbo cars (skylines etc) have much better drag coefficients than V8s from the 70s, they are also usually quite a bit lighter. It has absolutely nothing to do with the engine, power is power, it won't go faster just because it is a turbo :P
yeah i know, but i have been a member of the ford community for a long time and this is common knowledge. and its not any v8, only ford 8 vs ford 6. i dont know about other makes. the turb is lighter than the 8 im pretty sure aswell.
Here is the dyno graph from Aaron's R32 GTST.
Noel's has still gotta go back to the guy who did his exhaust to fix the dump and we also think his gate is a bit ordinary so it is making it a tiny bit lazier than this one. The specs on this one are:
R32 GTST
RB25/30
Standard hydraulic cylinder head with Pon Cams
No VCT connected
GT3788R 0.89A/R
HKS 800cc injectors
Microguess LT10
Blitz ID3 EBC
Just Jap 100mm intercooler
Full 4 inch exhaust with screamer
You can see it makes 10psi by about 95kms. If we had VCT on it would be making 1bar before then. Noel has much better specced camshafts for this turbo also so when we held the gate shut, it was actually making 6psi at around 2800 and 1bar at around 3500-3600
I should have Noel's new one once we get his small issues sorted out
Standard box, nismo diff which may have been a different ratio (not sure), the drag radials are much higher profile though which would also contribute to the ET
Why didn't you have the VCT on? It is also ready a lovely graph but it would look even better again with it on!
VCT isn't hooked up on this engine. Has the solenoid but no exterior oil feed. Budget build I did for someone about 3 years ago
And yes, agreed, VCT would be awesome.
So are you guys saying that weight has no effect on your trap speed? cos' an FG would have to be at least 300kg's heavier than a GTR
EDIT make that 200-250kg's
Yeah that's true but the car in question supposedly has over 1200hp at the wheels
with 1200hp atw and just semi slicks, there is no way the mph can reflect the hp in this case. obviously there is a traction problem. you never know how much power u are missing out on until u go 4 a drive in an awd car. trust me i know !!!! thats why gtr's are so fast. even if that ford is makin only 800whp, 135mph is still low. twoogle ran 139mph and 9.95 with 500kw. all bout traction.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
