looks like 2 rb's to make a v12 (similar to 2 v8s which makes the bugatti w16) LOL
those turbo's will keep the rear tubs warm, no need for tyre warmers
lol! I'm not sure what you're on but they need to raise or lower the dosage! NOW!!! :domokun:
There are folks in the US who have on Supras and Hondas that I have seen with gains over normal GT4202Rs. I know someone who is in the process of putting together a twin GTX4508R setup, though thats just silly.
Would that be on a nissan V8..? VK56 maybe in a rail...? :worship:
The rest of the page just loaded. lol
Rob is mad. :cheers:
Edited by WHITER33GTS-T
Could any of you blokes let me know at what level the std RB26 conrods tend to break.
I'm pushing high 300's with my GTR and the tuner said that on e85 the torque produced could be too much for the std rods to handle.
the motor has forged pistons etc but i left the rods std because when i had it built i didnt think i was going to attempt to push for 400kw
I was of the opinion that rods and rod bolts broke due to rpm, and pistons generally break from higher torque (heat) and detonation. Obviously the rods will let go eventually, due to power but I thought that level would be quite high?
I could be wrong though, someone feel free to correct me.
Edited by Rolls
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
