made it in by .5 of a rwkw :D
400.5rwkw
2530's
smallish cams, 256
Powerplus E85
mid to high 21psi
Racepace adj cam gears, all for response (let the E85 take care of the top end)
built 26, not 100% on pistons hence no 24psi runs etc.
that's some great torque! what are your head mods? what is your exhaust set up?
nice one mate. :) nearly 200kw @ 4,000 is not bad and 330kw at 5,000 is awesome. it must be hauling arse from about 4,000 upwards. I'll bring the 32 down soon. mine has slightly bigger cams, bigger exhaust, 2530s, HKS manis vs your tomei manis but otherwise our set-ups are similar. if mine cracks 400kw at 21psi I'll be over the moon. and then see what it does on 25psi!
400.5rwkw
2530's
smallish cams, 256
Powerplus E85
mid to high 21psi
Do you have any more graphs please?
Would like to see where it starts to come on against my 3L with 5's.
Old tune, first dyno pull, EBC off;
3000rpm 150kw
4000rpm 235kw
5000rpm 280kw but it's already hit top boost without the EBC and stays there till redline.
Seems the best setups are 5's or 2530's although the 5's have that extra low end at least on my untuned engine.
That torque curve looks like a real handle to drive, what is it like ss8?
It's 4WD ATTESSA... all that it comes down to is tyres.
Good rubber, forward movement.
Bad rubber, sideways then forward movement.
Either way justplant the foot and hang the fk on.
3000rpm 150kw
4000rpm 235kw
All things being equal the latest result posted doesn't make the RB30 look that good. Noted: different fuel, etc.
just found this so i thought id add;
full hks step2 head (272&280cams, valves, and hks spec ported head)
full hks step2 bottom end
trust drag cooler
greddy plenum with larger throttles
t88-34d 22cm
hks silent hi-power exhaust (full cat, mid muffler and exit chamber)
pump fuel + 20psi = 468kw + 590nm @ all 4 (7800rpm)
Edited by dahandfull
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
