^ very true as my old setup made 345rwkw on 19psi with pump fuel
10:1 AFR's will do that :P
But yes, check the dyno results thread. Average is around 360-370rwkw on 20-22psi on a 2.6ltr
The cars up around 400rwkw are bigger budget motors, strokers, usually & running 22-25psi.
  • 1 month later...
R32 GTR RB26det
T04z
Power Fc dejetro
Tomei Poncams
Tomei Oil pump
Tomei Sump Baffles
Built motor
Running Eflex
1650cc indy Black injectors
2 x Bosch 040 fuel pumps
Twin entry fuel rail
Os Giken rebuilt twin plate
Blitz SBC EBC
Apexi 48mm External Gate
4 inch dump
638hp (475 kw) @ 26 psi
Edited by 800KD
made it in by .5 of a rwkw :D
400.5rwkw
2530's
smallish cams, 256
Powerplus E85
mid to high 21psi
Racepace adj cam gears, all for response (let the E85 take care of the top end)
built 26, not 100% on pistons hence no 24psi runs etc.
256 cams. Are they just the poncams? Can you confirm the lift?
thought ud like that 1 :)
yea i need to sort out one of those go-pro's and mount on the roll cage... cause aint no way that someone can hold their arm still, even in current state to film it..
hopefully having a PI shoot coming up in a few months (fingers crossed)
Lucky you with a PI shoot!
Here's what we use locally for camera mounts, havnt had one fall off yet and they've wouldve fallen off for sure by now if they ever were going to. Drags, hillclimbs, motokhanas, track days etc - nothing phases it. Doesnt come with a go pro but you buy that separate. Link is http://www.launchhelmetcams.com.au/accessories/gopro-suction-cup
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
