I like the torque curve to see where the power comes in and or drops off.
Torque is what makes the car go.
My boat has the torque of a big block, 650nm and about 600ish at 4000rpm if I'm remembering right.
I loves the torque.
I loves the torque.
You can calculate it from the power graph if you have the rpm but yeah always nicer to just have it from the dyno print out.
What is your setup man? Give us a brief rundown
i went over it in the nsw area ( http://www.skylinesaustralia.com/forums/topic/369768-why-so-many-window-lickers/page__st__20440__p__6192319#entry6192319 ).
built 25/30 + GT35 + stock head bar stronger valve springs + 26psi boost
2000 RPM = 60kw
2500 RPM = 80kw
3000 RPM = 130kw
3500 RPM = 180kw
4000 RPM = 260kw
4500 RPM = 310kw
5000 RPM = 350kw
5500 RPM = 390kw
between these two peaks at 394kw
6000 RPM = 390kw
6500 RPM = 385kw
dyno run ends early, limiter is set at 7500rpm
26psi @ 4000-4100 on the dyno run
crappy mspaint overlay - there is still no replacement for displacement it seems
We should put in a plus/minus variation to allow for ahhhh... dyno discrepancies, yeh lets call it that... say +/-2% :)
given the 2% rule mine would get in....
Would be keen to see my graph overlayed if any of the computer competent people are willing to do it.
Specs: 26/30 with GT35, .82 rear and some "nice" cams, makes 396-398kw on 20psi boost (wont hold any more boost)
Makes 23psi at 3200rpm, rev limit set at 7500.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
