can i have a drive of your car Steve ???
i'll let you drive my 235killa wasps :)
how do the RS's respond on a 2.6L compared to your 3L?
Lol, maybe :huh: Wait till the brakes are on it and the tune finished, then it will be much nicer
never had them on my 2.6, but in other gtr's with them on, I havnt been impressed-for all that lag they may aswel be a to4z
  • 4 months later...
425kw's at the rear's best so far
HKS Step 2 - 2.8
HKS Twin GT2835's with 0.6 A/R's
Nismo inlet manifold
20psi
HKS Step 2 - 272's
HKS Twin spark with Spiltfire's
Power FC
Pro ported head and chambers
8.7:1 comp ratio
No print out handy at the moment but should be shortly
  • 2 months later...
atm sitting on 410 rwkw mods include;
ENGINE:
rb25det block
rb25det head no work done
linshed standard crank shaft
cp 20 thou oversized pistons
eagle h beam rods
acl hardened race series bearings all round
arp head and mains studs
n1 oil pump
remote oil filter with 15 row cooler
n1 water pump
hks 264 duration camshafts
hks adjustable cam gears
plazmaman plenum and fmic
sard 850cc side feed injectors
aeromotive fuel regulator
hks t04z turbo .82a/r rear housing
6boost highmount manifold
hks 50mm wastegate with screamer
3.5"dump pipe
high flow cat
3 3/4" cat back
FUEL SYSTEM:
bosch 040 intank fuel pump as lift pump
2l surge tank
twin bosch 044 inline fuel pumps
twin #8 fuel lines to fuel to twin entry fuel rail
TRANSMISSION:
jatco 3 speed manualised auto
400kw transbrake
18psi stall convertor (4,600 rpm)
13 row oil cooler.
ECU
haltech E11v2
FUEL
BP ultimate 98 oct
CP Pistons
Eagle Rods
Tomei 1.2mm Headgasket
Tomei 1mm Oversized Valves,
Tomei 270/270 Procam 10.8mm Lift
Tomei Valve Guides
Tomei TypeB Valve Springs & Retainers
HKS GT-RS
BNR34 with 425awkw on e-85! Who says HKS GT-RS on 2.6l is laggy? :(:O:)
Was pushing for 30psi, but due to catalytic converter boost dropped to 25psi will fix and decat it to make 450-470awkw
hahaha its the 94mm trust exhaust. Though i bought a metalcat and its probably what is restricting it they said as i got it installed and after the front pipe it joins at a 3" then the trust 94mm, though it will definitely get fixed up and sent back to powertune in a week or two so will definitely update to see it go past 450awkw
Hmms R31, why do you keep saying rwkw? I ran it on a awd dyno at powertune. Hmms not sure if i can make 500awkw on my engine, might be able to on higher boost, but only problem is i am only running SARD 1000cc and really i find it no point pushing it any harder, am happy with 30psi because it fliesssssssssssssssssssssssssssssssssss so who said gt-rs was laggy on a 2.6L? ;)
hahaha n1gtr, no need and no point wasting anymore money in my opinion! i do have a 3L block in my garage as an 'option' if i wasnt happy with GT-RS and 2.6L
Though from what i experienced today and knowing it will do 450+ as soon as it can hold 30psi anymore power is just ridiculous!!
My only goal was to just have a 10sec gt-r haha! will run soon!
Though maybe if you took me in your 26/30, hmm i might change my mind? How about i take you for a ride and give me one then and we'll compare? ;)
awkw/rwkw same shit mate.
GTR's are NOT 50/50 fulltime 4WD like a EVO/STi. People need to start realising this.
It's been proven time and time again there is minimal difference between the two. 10-15kw difference as tested on several cars over 400kw @ the wheels by various users now on various dynos. Have a search for the threads if you don't believe me ;)
IMO 425rwkw/awkw and E85 is a poor result for that much boost when -5s (read: smaller turbos) would make those numbers on 24psi/E83
Oh and you easily have a 10 sec GTR with 425rwkw, you can run mid 10's with less than 400 :D
awkw is run using four wheels, rwkw is using rear wheels? hahahaha...
I know its not 50/50 but you would still consider it awd right? 60/40? still an awd system.
Anyways, i already the difference and have seen and read it several times. It is only running 25psi for 425awkw as the boost is dropping. Either way its because i told him not to push it too far also as i dont want to make the extra power and then risking the motor. Either way everyone knows its not always about the numbers, its about how it drives and as i said, who says hks gt-rs lags on a 2.6l? :D
Hahaha yeah i know, a mate of mine ran 10.98 with 350awkw so i know its possible just wanted to do a time for myself
Though maybe if you took me in your 26/30, hmm i might change my mind? How about i take you for a ride and give me one then and we'll compare? :D
Deal.
Broke my foot yesterday so it won't be soon thoufh
hahaha woot! two offers to see what the 26/30 is about... yes i am in sydney guys! Maybe we'll meet at the r32 cruise on 10/10?
I wont be going to cruise, will drop by at penrith though and if anything we can go for the spin there? ;)
Hopefully be running 450+ by then and you guys can tell me what you guys think? :D
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
