how big is your exhaust marko?
its the veilside evolution system - its 95mm i think (i.e. either 3.75" or 4" from the dump pipes to the rear)
the dump pipes are large as well.
You'd want 4 inch minimum? or twin 3's haha hey Paul...
my brother has the apexi n1 systm on his trophy (last registered in 04) which runs 2 x 3" pipes, sounds very g-rough :)
What about in the mufflers (well the rear one). My Kakimoto had a 2.5 inch restrictor in it. What a POS! Silly jap systems!
curiosity got the better of me so i looked under the car with my vernier set...from the dump pipes it runs 2 x 2.5" front pipes (60mm) then the front pipes run into a 3.5" (90mm) collector which is about 400mm in length, the exhaust then runs straight thru @ 3.5" (90mm) via 2 middle mufflers which retain the same internal diameter. the rear muffler i looked thru with a torch & also measures 3.5" internal diameter.
this engine is running tomei poncams 260degrees @ 9.15mm.
this morning i took the car out & wanted to see exactly when i have full boost - are u guys ready for this??? 0.8bar @ 5,500rpm with gtrs's. its only on 0.8 bar until i get it retuned. huuuge difference from my rb26/30 which made full boost in half the revs.
i modified this gtr almost 10 yrs age hence i couldnt remember the exact spec of the exhaust, tell you what though, i am very happy to have it back home.
LOL! You know where they need to go? In the dumpster along with 2540's. But im sure there is a big pile of those in there already!
what is your rev limit set to?
if i look at my current power band, it is 3000rpm (i.e. 5500 - 8500)
when i think back to my rb26/30 i'd always shift at about 6500rpm which would still give me a 3000rpm powerband...although the rev limit was set to 9krpm, i always felt like i was killing it going past 7krpm as the engine was nowhere near as 'rev happy' as the 2.6ltr (i guess its changing mindset as well)
Just pulled out my latest graph. I hit 0.8 bar at 3400 RPM which is about 75 RPM after the dyno graph starts. RS's was 4600 RPM which was 1400 RPM after the run starts.
i remember doing this exercise with my 3ltr with -10's & i was getting 1 bar @ 3000rpm in 3rd gear on the street, i posted it somewhere on gtr.uk website
although, comparing a 3ltr with -10s to a 2.8ltr with -5s isn't really fair due to increased capacity
was set at 8600 but I never revved it past 8000. Even at Winton I was changing at 6500 - 7000. I didn't need the revs. With the RS's It needed every last RPM it could get so it wasn't so lethargic when pulling the next gear... not that it helped! From 4500 RPM I have 275 kw. Now if I changed at 8000 it will land somewhere between 5500 - 6000 RPM, thats 390-410KW after gear change, back up to 425 at 7100 and 418 at 8000.
So roughly 1800rpm later to 0.8 bar than a T04Z... and people compare them ha!
yes - what size rear housing on the t04z are u comparing it to as there are a few combinations?
my mate used to run a single hks gtrs on his r33 gtst & that had amazing bottom end power
0.84
It just goes to show that capacity can hide dog turbos flaws but they are still dogs...
HKS 2540 is a classic example, actually not too bad on a RB25 but on a RB20 probably the worst turbo ever!
Has that graph been replicated by anyone else or just a one-off? What capacity?
Always a bit sceptical when theres no corrections on a dyno dynamics graph for all we know that graph could be stock turbos with 200 degrees of intake compensation.. Before xmas my car made 492rwkw on e85 and 26psi on a pretty hot day with 28degrees AirTemp 49 degrees InletTemp compensation worked in the figure i thought nice not much to go till 500 now. After having a few problems we stopped tuning for the day, 2 days later went to another dyno, tune unchanged made 460rwkw i was like :mad:
Anyway dynos tell porkies we need more mph on the 1/4 in this thread.. :cheers:
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
