I must be missing something, whats the relevance to this discussion Marko?
I am making a statement that its a nice car, is that not allowed on sau?
about the same relevance as that 300,000 word 20 year old sig quote
hmmmm...i will amend my sig if its that much of an eyesore
Thought that may be the case!
enough with the bait! give it a rest
Always a bit sceptical when theres no corrections on a dyno dynamics graph for all we know that graph could be stock turbos with 200 degrees of intake compensation.. Before xmas my car made 492rwkw on e85 and 26psi on a pretty hot day with 28degrees AirTemp 49 degrees InletTemp compensation worked in the figure i thought nice not much to go till 500 now. After having a few problems we stopped tuning for the day, 2 days later went to another dyno, tune unchanged made 460rwkw i was like :mad:
Anyway dynos tell porkies we need more mph on the 1/4 in this thread.. :cheers:
There was a full thread on the car specs if you want to know more - rb29 was in the title IIRC.
"RB29 wow". Great thread, and that graph is pure car porn.
Hey question for you guys.. Im currently building my engine, and a thought crossed my mind.. The gtx3076r's compressor map shows it can flow around 65lbs/min of air at ~29psi. Could this translate into a hopeful ~530 - 550rwhp? Or ~400rwkw? I mean, could it be done for sake of argument..
The housing configuration i figured would be a 1.06 T4, most likely divided and mated to a twin scroll manifold.
Any thoughts guys? :)
I wouldn't, not unless you've seen anyone push one that hard and make that much power on a dyno type that gives results which reads in the area you aim to reach that power on. You certainly won't be getting that power from one on pump gas on any dyno, E85 or something similar would be a must.
400kw should be achieveable on E85 with a GTX3076R at least on a hub dyno, actually even potentially with a run of the mill GT3076R.
I thought the same thing, the GTX3076 compressor flows nearly 5 lbs more than the GT35 on paper so 400atw should be theoretically possible with enough boost.
Was definately thinking the e85 route aswell. IIRC, some of the supra guys have them running 26psi, so i figure the odd jump to 29psi would be ok. And because of the 1.06a/r, EGT temps *should* be fairly acceptable.. I think?
Wouldnt the gt3076 be out of its ideal efficiency? I mean, i havent seen one go past ~24psi, but then again i havent looked for that exact figure..
My build should be done around september, so might push it to 29psi to see if its achievable.. For science-sake :)
Scotty, glad to see im not the only one! :D i know the gtx are marginally slower coming onto boost, but i figure the divided housing mated to a twin scroll mani should bring it back to bee's dick of difference.
Thanks for the input gents! :D
The normal GT3076Rs have been pushed up past that before and made good power, but yeah they are definitely pushing shxt up a hill. I reckon the gun choice for what you're looking at doing would be a FP GT3076RHTA personally.... have a look into those while you're considering it.
They are claimed as 59lb/min, which sounds underwhelming compared to the GTX but bare in mind the maximum flow is rated to whatever flow efficiency the company decide to use as a cut-off and isn't an absolute - and also Garrett themselves have ultimately said the 77mm compressor used on the GTX3076R isn't suited to the GT30 hotside by putting it on the GTX3576R, the extra flow is argueably redundant on the GT30 turbine.
I think the HTA76 wheel is basically the ultimate compressor for a GT30 turbine, the most flow you could put through that turbine with better response than a normal 56trim GT3076R wheel.
Problem with ramming so much boost etc, what happens if you get a slightly average batch of fuel?
There is really not enough room for error running uncontrolled fuels in street cars.
Mine is lasting well so far, haven't had any bad batches of Caltex yet either according to the wideband anyway. I did hear it pinking once on cruise one of the hot days we had, but its running 18:1 there for economy atm. >_<
Im not scared about the little VQ, seen many stock VQ30det's pushing big numbers (400-450kw) and the VQ25det runs the same rods, the main worry is the auto. Either way, I have spare engines and a trans here.
I doubt 400 is attainable with the auto, (I would be happy with 350) but a built RB with a GTX3076 would sh*t it in. I will check out the HTA76 further Lithium but I think the compressor housing is a little too big. Does it still run the Garrett rear?
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
