Proof is in the pudding. But still dubious of the 300-400% claim. Can someone point me in the direction of a good article on this?
My understanding from the old Iron Carbon diagram has always been strength-Ductility-toughness vs hardness is greatly dependent on the rates of heating and cooling etc and grain size and type. With cryo freezing you are not changing the grain structure type/composition, rather just refining the grain structure by making it slightly smaller and more uniform. So you are not increasing the UTS etc of the component, but stress relieving it so that it wont fail at its weakest point.
At work ATM, will post up excerpt from textbook tomorrow. But yeah basically what I got from it was that you're not actually make the gears any stronger.
Please don't get confused here... strength and hardness are two different properties. Hardness will most likely increase as a result of cryogenic treatment due to the formation of martensitic grain structure in the steel. With increased hardness the material wll become more brittle.
But this is just piss in the wind, I doubt anyone knows what steel the gears are exactly or if anyone has examined the grain structure before and after to know whether it has actually made a difference.
Ring Heat Treatment Australia. Their exact words were: 'improves the strength of the metal by 300-400%'. This certainly does not mean you are wrong, just relaying what they said as I am definitely no expert
They do the same thing to ambulance rotors and get more than double the life out of them. Not sure about the formation of martensitic grain structure but I know for a fact the gearboxes we have done are definitely stronger, which is the point.
I wonder with the ambulance rotors if that affects braking power?
I was always under the assumption that softer rotors provide better braking. With ambulances though, it is only designed for street conditions so that would be ideal for longevity.
OK I have finally made it to the 400 kw thread.
Car running rb26 block and -5's
Car made on 19psi 420rwks - I'm wrapped :D
Massive thanks to Trent & Cat from Chequered tuning who tuned the car over the weekend (wouldn't go anywhere else)
Trent tuned a felxi fuel set up on my Autronic
Also a huge thanks to Tas (Power Glide GTR) for getting the car to where it is - car has turned out mint mate :)
This is a hub result, yeah?
yeah, but my car has read 350'ish awkw on 98 at Chasers 4WD dyno and 356rwkw on 98 at Trent's dyno. I'm due for a service and what-not, so i'll try and can get a Racepace one done as well.
For Melbourne, Trent's dyno is inline with all other big shops
i was under the impression it was 20psi
doesn't sound that far fetched... i got 400rwkw on 256 cams at 21psi - this car has bigger cams would seem reasonable i guess
It's E85 as well remember :)
420kw on 19psi is.....questionable.
Your kidding right !!
I dont jump in on these threads much but I've seen plenty of cars in Japan running 1.3 bar and pushing well over 400kw.
I know of a few floating around oz as well.
You dont need big boost to make response and power, just a well built motor top to bottom.
well if its a hub dyno then yea its goin to read higher,
mine made 375rwkw on a chasis dyno, on gate spring pressure which was around 18 psi
cam gear set on 0 and on Pump gas
LIke Marcus said, everything needs to be set up correctly.... EVERYTHING!
and everyone else has missed the fact the Trent's dyno DOESN'T read higher than other dyno's in melb :rolleyes:
It made 370rwkw on 98, which is about what you'd expect for 98 for '5s RB26 - it's around what the RP cars make on 98, Chasers cars make on 98 etc. If an RP car came up in a thread saying they made 370rwkw with -5's on a 98, no one would blink an eye and think it's just par for the course.
Hub dynos read higher if the operator wants them to read higher
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
