the plug in vipec and links are non sequential batch fire. aka z18et spec..
the wire ins are the way to go. the fact you have to hack up a standard ecu case to fit them aswell is a pain..
the haltech is quite good as it has all the built in knock control and is a "plug and play".
rb25 has forged pistons and rods, n1 pump with crank collar and ross "power steering belt flinging" balancer.
Does the knock control on the haltech actually work?
Joined the 400kw club but Im chasing some answers to some issues we had along the way if anyone can help......??????
The car is a r32 gtst with rb26, dash 5's, vipec
This was the pulp tune
sharedmedia=gallery:images:83182]
Went to E85 so changed the injectors to id1000s and went for another tune.........
mark2
As you can see the car was suffering a fairly severe misfire at 4500 which after changing plugs 3 times, coil packs, cas etc had myself and the tuner completely stumped. The misfire seemed to be heat related as it got worse the hotter the engine got and even on lower boost the misfire was still there at the same revs.
The car runs a vipec plug in and after pulling our hair out for 5 hours on the dyno trying to diagnose the problem and out of pure desperation we put a haltech ecu in the car with a map from a gtr and the miss was gone.
Has anyone ever heard of this issue and have any ideas?
Coil charge/dischage settings.. or dwell settings....
Over-driving the coils with too much current will run them too hot, and that can cause a miss.
The issue will then get worse with heat. The coils themselves handle the heat, but the ignitor module gets upset and will cause miss-fires.
I can't be 100% sure, but from memory a maximum charge time of 1.2ms and a min of 0.8ms worked well for me with a wolf, but I wasn't anywhere near that power level with the engine that I was experimenting with this. Sorry if this is useless information for the vipec. I've never played with one yet.
Other vipec tuned RB owners might be able to share their ignition value settings...
Went through all of that mate had vipec guys on the phone etc it was nothing to do with that at all.
Funny thing i didnt mention was when we went back through some old dyno graphs from months ago it seemed the car suffered the same sort of issue at the same revs but it was not noticable as a misfire until the power was increased with the e85.
Iam a big fan of the vipec and would really like to get it sorted because as you can see from the dyno graph once the misfire is fixed and more boost is added it should make alot more power
It should also be noticeably more responsive - 20psi @ 4700rpm on E85 is bad.
So sort your issue and you'll come close to picking up 500rpm maybe more which is good :D
If you swapped ECU then it's clearly in the setup/settings of said ECU as opposed to mechanical like packs/loom etc.
Im not sure what you mean? The dyno runs were done in 5th gear. I cant drive the car the miss is always there and cuts in at exactly the same revs evrytime and its that bad it doesnt recover and continues throughout the rev range. It has to be the ecu itself as the miss was completely gone with the other ecu on a pulp 33gtr tune.??
Spent 5 hours on a dyno checking valve springs trying evrything possible, tried running it super rich super lean made no difference the miss was always there couldnt even do any power runs it wpuld just break down
I just meant that once you fix your issue, you'll get a good 500rpm in response, the fact you did it in 5th - even more if you do it properly in 4th (assuming it's a 5-speed) :)
It could even be a farked ECU, although not everyone has a spare of the same model to try out - just another thought given you swapped ECU's and the problem went away.
Given it looks like it's hitting 23psi now, probably not much more, maybe 15rwkw at the most really. Same as everyone else :)
However the real gains you are yet to realise all lie smack in the 4000-6000rpm range, you need to sort the issue(s) out. You are easily missing 40rwkw in that region due to your breakdown issues which in turn is hurting your boost curve massively and so on. It's all domino's when it comes to spark/ignition. Once it goes, everything else is affected.
Also, looking again @ the graph i highly doubt it was done in 5th. 8000rpm/5th is well over dyno dynamics speed limit/cut i would've thought.
it was done in 5th to try get more traction it was more consistant for trying to diagnose the missfire. We even tried going half throttle through to 6000rpm then 100% throttle after the missfire area of the rpm and it made it better. As soon as in was full throttle is would missfire exactly the same
from both my R34's, i never noticed a huge 'response' increase with E85, sure a stack more midrange and what not, but you're not going to be spooling -5's at 4000rpm just because you've switched to E85. Can't say i've really seen that sort of difference either in other peoples results.
You'll pick-up usually 200rpm at least from most results I've seen? And 200rpm is better than nothing.
But... My entire point is based around the fact that once the issues are sorted, he will have 20psi a lot sooner than 5000rpm like it does now, it'll be at least 500rpm if not more. :thumbsup:
I think the response comes from playing with the timing as the turbo spools, not the e85. I didn't notice any difference either.
But it's the E85 which allows you to dial in more timing. Which came first, the chicken or the egg? :P.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
