ive tried searching, but i cant really find the answer. can someone tell me roughly how much a standard r33 gtr incooler can support up to??
Im going in for a tune and im hoping to see around 360kws. should i upgrade before the tune or should it be fine?
Thanks
well i was thinking if anyone would know if itll be fine for 360 it would be people who have seen 360 and shot way past it :P
If it was so good he wouldnt have replaced it for a Greddy one in his 360kw 33 that his selling, the cooler wasnt designed for those power levels and you cant argue that it is 100% efficient. It might do the job but its not going to do it as good as a bigger unit.
Anyways not going to stir the pot, 400kw you will be hearing from me soon :P
Edited by nomnomv8
lol - I didn't replace it, it came with the car. I wouldn't waste my money on one.
We actually thought it was stock until 6 months after when I had it on a hoist/front bar off etc - given results/performance were no different to stock cooler equipped examples.
I could give you a list of cars making 380-400rwkw on stock coolers if you like? no issues at all.
Yes please
So it's proven that a standard cooler can support big power, but would a big dollar brand name one be more efficient and help to make more/earlier power?
Personal choice at the end of the day.
I wouldn't run that much power with a stock cooler and nor would I run aftermarket bov's.
Ive always based my choice on what the majority have done with their cars.
This will turn into a heated debate so let's leave it at that :)
My power, temps are no different with a GReddy core (that I didn't know I had). Guess you missed that post.
But spend big if you want on the 'big mark up' Jap items that are coming outta China at the end of the day anyway. Look forward to reading your testing and if you see any temp differences at the circuit, i didn't.
I mean I know for a fact a few local Aus 'brands' have been ex-China for over 4 years. That's another argument entirely however :)
yup i like the "brands" vs china debates they always make me giggle.
I have a spare plasmaman cooler which is a real work of art.
Has to be better than the HDI cooler which was fitted to my gtr when.I bought it back?
Ash, have u heard much about plasma man? They charge a bomb but very nice quality and they do make them onsite :)
Its not China its worse..Thailand !! Well at least one major Japanese manufacturer has gear made there.
What where the dimensions of your GReddy cooler?
This.
People are forgetting that coolers are basically a heat sink, a heat sink that's in this case 20 years old and was designed to cater for "206kw" at the fly... not almost double that at the wheels!
Common sense, a cooler thats 600 x 300 with a depth of 60mm does not have more volume than a cooler thats the same dimensions and 100mm thick and at those power levels mentioned you have to have rocks in your brain not to realise that. Look at the Nismo coolers for example I guess that their engineers are dumwits and idiots not knowing that their 100mm thick coolers are useless because some nobody from a workshop in Australia said so.
The point im trying to make is when you have already spent $10,000+ to get your 360kw+ car you think that you would do it right and invest that couple of hundred more after selling your uber cool OEM GTR cooler to a GTS-T owner..
Each to their own I guess, il do things the way they work for me, everyone is entitled to an opinion and while my opinion might be seen as "worthless spending" so be it, rather that than do what i believe is stupid and goes behind any engineering principle
I got my results with 2/3 of a standard 76mm Greddy cooler. A full one would be fine for 400kw, so would a stock GTR one as proven already. Why change what doesn't need changing is most peoples opinion.
As with stock/aftermarket radiators, thick coolers aren't as efficient at cooling as the back of it is always seeing warm air, plus you pay the lag penalty most cant afford at this power.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
    • I promise there will be no chance of replacing the rad support....  It is barely twisted and it's way more likely to just be driven around with a slightly twisty support. As long as the headlight can be bolted in there then no harm no foul lol. The reo may need to be un-bent a little but truth be told if it all somewhat lines up and is hidden when the car is assembled the level of f**ks will be 0.0
    • this thread delivers, once again Skyline owners, our cars spend more time off the road than on the road
