Thermodynamics. Higher boost pressure = more heat.
For the same turbo yes. But when people are running different turbos etc then the thermodynamics of each compressor vary greatly and I think its an assumption to thing that say a GT35R running 20psi will heat the inlet air more then -5s at 17psi
.....I think what he is trying to say is that a 4L motor on an XR6 requires less boost (since its a bigger container) to get same airflow and HP as a 2.6 Litre motor does all things being equal - and therefore is concluding there is less heat to take out (due to less boost required) and hence a smaller intercooler for same or similar effective output....
...I did read that the Hybrid coolers flow real well with very little pressure drop even at some big numbers. But when you look at the inlet temp at the manifold its higher then you would like to see. Whats the general rule of thumb on inlet temps again? Its something like 10deg C is 1% of hp ?!?!?!?
What is peoples experience of intercoolers and inlet temps? I have alway observed an inlet temp within 20deg of what my AC says is ambient temp. No idea if thats good or not...i know I have a HKS air filter and no cold air shroud around it
How good are ARC coolers? Got one on my gtr, looks to be 70ish mm thick, delta fin style I think, definetly not bar and plate or tube and fin...
Would they support mid to high 300kw at 20 plus psi? It isnt that thick, could this be a problem?
It Came with the car otherwise I would of still be running the stock one lol
It's fine. Steve has a 70 mm ARC well past 400.
Daniel with the Midori 34 has a 70 mm ARC and has cracked 400 with 2530's.
Interestingly they mention the magic 400kw on their front page and offer a 'big' intercooler for it...
Doesn't say how big - just in the 'intake size'.
And read the rest of the sentence :)
If chasing numbers in the 400 rwkW plus range you can order what is known in-house as the BIG BIG cooler. Still using the same intercooler core this until has a larger alloy cast end tank that takes a 63mm inside diameter hot side intercooler pipe
Anyway I'm going on holidays for a fortnight. Keep discussing, i'll return and call you all wrong in 2 weeks :P
3500 RPM = 150 RWKW 400 nm
4000 RPM = 210 RWKW 500 nm
4500 RPM = 300 RWKW 610 nm
5000 RPM = 355 RWKW 660 nm
5500 RPM = 395 RWKW 655 nm
6000 RPM = 412 RWKW 645 nm
6500 RPM = 412 RWKW 590 nm
7200 RPM = 412 RWKW 545 nm
Limited to 7500 RPM, and running out of injectors
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
