Anyone in here know of a place to get the push in fittings for RB26 cam covers with a 90 degree outlet?
NOT a straight then add a Speedflow 90 degree bend - that wont fit. Needs to be the same fitting that goes into the cam cover that's got the bend in it
Tap the covers and run a 90 degree male union?
Yeah if nothing's available then it's going to be something along those lines. Prefer to be able to just get something off the shelf of course though :)
EDIT: That is.......if if exists somewhere haha. Pretty doubtful but worth asking
I just want to know a couple things from you 400kw guys i wana know,
What sumps you guys are using if in melb where u got it from size cost and if from out of melb cost of freight
Can the std intake piping and cooler support 400kw ? Coz i wana try keep it for now cant afford it,
Std exhaust manifold port matched to gasket will it flow 400?
Cheers
Depends on what you are using the car for.
Street only, just buy a Tomei baffle plate
Any kind of track work we get Extreme Custom Engineering to make a custom pan and gated system to whatever size or shape or configuration we want. $1000-$1100 usually. They are in Brisbane. They do very good work though
They do fit.....you just have to cut them down lower before you weld on the -12.
Use a 90 deg on the intake side and a 120 deg on the exhaust side. Speedflow's new range of 100 series hose ends are all tight radius now. If they aren't tight enough then try Proflow or Aeroflow
Dan just to be sure, you mean modify the actual cam cover right, not the fitting? Because I cant see how the fitting can be modified to make it lower.
I'm sure if it was an 05U height block it would be direct fit, this is RB30 so on a 32 the bonnet clearance is shocking.
Have you modified any cam covers in the past? Got any pics of them once complete by any chance please?
Yeah we did it on a 26/30 in a 34. Custom bonnet though.
I did them at standard height. You can get them to sit about 10mm lower by cutting off the lump in the cover before you weld on the -12 fitting.
I'll try to dig up a photo but I'm not sure where.
There is also a mod using a landcruiser(?) engine mount which sits the engine another 10mm lower I think. I'm doing research on this at the moment
why don't u stick with the OEM fittings as then u won't have clearance issues (I didn't on my setup)...or is the OD incorrect for your plumbing?
[RH9GTR] has them on its RB26/30 in an R32 GTR with stock bonnet....check engine bay pics ;)
Seen that before. They rise up too much, it doesn't look factory enough for me - it's not only about fitment. I have a raised trailing edge so the clearance is fine for now but if I change that in the future it will be close but still should shut.
Stock ones look terrible IMO and means I cant use AN fittings which the rest of the engine bay has. And yeah that makes plumbing that little bit more fiddly.
Would make it a non cover removal job, and I'm sure other peeps would like some.
Yeah agreed, would be popular. Don't know if I can be bothered with all that though - don't really want to spend much time on this part of the car
Thanks that would be great!
I'd be keen to hear more about lowering the engine. I know several RB30's have been put in at stockish heights, but everyone seems to do it differently. There's a market for bolt in mount kits, so everything needed to install RB30 to R32GTR in one package.
Is it 1000 delivered? What to do with my sump?
$1000 approximation on a sump and you are asking if it includes delivery?
I wouldn't have a clue what delivery would cost you. I drive up to his front door, drop off a sump, tell him where I want fittings and what I wanna do with it and about 2-3 weeks later I get a custom GTR sump back
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
