Thanks that would be great!
I'd be keen to hear more about lowering the engine. I know several RB30's have been put in at stockish heights, but everyone seems to do it differently. There's a market for bolt in mount kits, so everything needed to install RB30 to R32GTR in one package.
that guy simon has the worlds best kept secret on lowering the engine but he won't let the cat out of the bag
.I have 1 theory which I've discussed with another mechanic and would work
I heard of a trick using rb20 engine mounts which lowers it 10-15mm. Though dont know how accurate that is as I havent done it myself.
How much lower would the engine need to sit in order for the timing cover to not hit the bonnet bracing? Would 20mm drop be enough?
I recently did a 26/30 for someone. It required an 8mm drop, bonnet support cut out towards the front and the twin turbo 'badge' shaved off the twin turbo pipe to make it smooth.
With all that, it only just touches by a whisper.
With a standard bonnet I'd say 25mm would see it clear with no other changes.
I'm fairly sure RB20 mounts are the same height as GTR but I could be wrong. The other problem with lowering the engine in the subframe is the clearance between the sump and the subframe is only about 15mm at best from factory. You could possibly go 10mm of that but I reckon driveshaft clearances would have to be considered if you did
exactly what i did to mine - cut the bonnet brace above the front cams, took off the twin turbo badge & milled off the boss for the badge.
funnily though, i had to run the bonnet without the insulation as this was starting to rub the paint off my newly painted covers. that is how tight it was under there!
I was thinking if you could achieve say half inch of lowering engine towards sub frame via engine mount mods and then lowering sub frame half inch off chassis rail then you would be pretty damn close and both of those things are very straight forward and have probably been done before. But as you said you would need to look at drive shaft clearances and angles.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
