hey people i got a 1993 r32 gtst rb20det!
the original gear box blew the centre bearing,
i thought do it properly and bought a re-built box from a local importer,
thought it was properly until, the box blew 3rd gear, just doing a simple down shift ready 2 speed up, with all but 1 tooth left on the gear.
the importer replaced it under warrany, hopefully would all be ok,
then that box died and a syncro moved around 5mm away from the gear.
that box was replaced under warranty also.
next box thought would be ok, 5th gear just seemed 2 dissapear one day and started too demolish the rest of the box,
took it back importer said it was because i didn change the spigot when i did the first box, so he replaced that and put another box in under warranty,
well now that next box has lost 5th... same noises same problem as the last one, put it in 5th and there is just nothin there, has a massive wine on idle and driving!
any ideas why this one might have blown the same thing?? no its not my driving either!!
thanks a lot
any opinions would help!
lee
https://www.sau.com.au/forums/topic/251835-gear-box-help-needed-asap/
yeah the importer wont keep doin em i dont think... not like tha car has a hell of a lot of power! lol fair much stock, would say pulling around 160 atw lol!
its more the inconvenience that is giving me tha shits!
You get what you pay for.............get a ppg gear set.... wont be looking at it ever again and can thrash the crap out of it..
  • 4 weeks later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
