hey guys...
heh pardon my ignorance...
im drvin a 95 r33 gts...no turbo...:)
just wondering, occasionally, now that im informed by bam n sum otha ppl i can just pop by the plex on a sunday and do runs if i like, is there nething i shd be aware of?
like driving yr car hard prolonged could lead to this that this that...
an occasional whack to 180 on private roads? can spoil e car?
just wondering...if theres nethin i shd be aware of or shd not be doin till i do anythin to the car
thanks
:D
https://www.sau.com.au/forums/topic/25187-drving-hard/
not really unless you're doing circuit work....just watch out for the oil and water temps....
but for the occasional road excercises....there shouldn't be much of a problem...just keep your heater on for a few minutes should do fine...
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-535748
These cars are meant to be driven hard.
To me it's like asking if your BMW M3 can be safely* taken up to 250km/h (*mechanically speaking of course).
Skylines are supremely stable at very high speed. The motors are very responsive with the balance to go to the red constantly.
At speed I fear nothing for the car - just the police :)
T.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-535751
< snip >
driving hard? Talk about reading hard. :( That post was frikkin impossible to read.
But from the little I understood, no there should be no permanent damage as the car was designed to be driven hard. The occasional fang won't do damage unless the car's not been maintained well.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-536707
skylines love bring driven hard...
just keep good fresh fluids (engine, gearbox, diff, brakes, radiators), good plugs etc.
And of course, like fatz said, you need to get sump baffles installed if you want to go over 100km/hr.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537273
good point actually.. like how much punishment can a skyline take day in day out without it actually snapping? Do they start blowing smoke and things? I've never actually seen a skyline that looks "sick" but i guess they aren't at that age where that would become obvious I spose..
not that i really do that to my car, but just curious :P
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537425
the only answer is "depends", but I regularly take my stocker out on the track and use all of its potential when I'm out there.... never had a problem.
Personally, I think with quality fluids, stock boost and mixtures they can take plenty. Its when you move outside the tolerances that the manufacturer expected that you can have problems.
And don't forget a sump baffle.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537431
haha just take Gtrken for example .... takes a R32 GTR wth an awfully worn motor .... drags a Mits GTO .... yeah hurts it a little but it keeps solidering on ..... then takes it to JMS drifta-thon .... with clutch n engine worn gives it a good thrashng there .... starts makng weird noses after but it still soliders on
...... theres cars are meant for this over a long period of time .... sure theres going to be slight damage over time but for most part thats why they are called "performance" vehicles!! they are built for speed n an occasional hammerin ..... dont stress .... enjoy!! :D
....... i accept no liability in engine harm that comes from this advice :D
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-538309
A baffled sump will stop the oil from collecting at one side of the sump under hard cornering, which means you won't get oil surge. A baffled sump is desirable if you go circuit racing, but not really necessary for drag racing unless you doing 10sec or better:D
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-541196
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
