Ok i need some help.. R33GTS-t Si (1993) making 239rkw
When i was at the ahg track. I was able to take my car for a spin. now when taking tight corrners or sharp left right turns the car would kind of (I would get to the conner then when powering out its like there is no fule getting to the injectors.. i have a totaly stock fuel systerm but i dont know if it is this...) so like surging i have tryed making corners when the tank is full to the brim and it still happens...
i dont know what it is realy..
Sparks, Fuel filter, pump injectors ahhhh
thanx for ur time
https://www.sau.com.au/forums/topic/251873-surging-when-taking-corners/
+1 for the fuel pump.
If you running at a track, I do not suggest you get a Boche 040. They have a crap pickup design, and don't go all the way to the bottom of the tank. THey are also noisy.
THe best pump I have used so far is a Nismo 275lph. The Tomei version the exact same pump. You can feel the pickup touch the bottom of the tank well. And they are the quietest, and easiest to fit pump.
If you're doing track work, then the extra $150 is well worth it. Plus this pump will support well over 300rwkw.
