hey guys would just like to know what i can upgrade my pump to without doing any major modifications. for example could i pretty much plug and play a 32 gtr or 33 gtst pump where the stock r32 gtst pump is? or is there abit of modifying? also would i have to run gtr injectors or after market ones if i ran one of these pumps?
my car is just absolutely stock and fuel pump could be one of the reasons of my power cut out issues so want to rule it out plus might aswell get something abit better.
i just want something a tad better then stock without having to modify anything. let us know what way would be best.
https://www.sau.com.au/forums/topic/251887-fuel-pumps-compatible-with-r32-gtst/
Personally, I wouldn't bother. For what you are running maybe a bosch 040 would be the best recommendation.. That is if you really have a problem with your pump. Have you had it on a dyno and seen what the fuel pressure sits at on load? Have you beefed up the voltage at the fuel pump (relay switched direct feed wiring)? Do the real easy things first before you swap parts out, work smart, not hard. Always start with diagnostics.
I wouldn't know about any others, mine came with a gtr pump and now has a bosch 044 intank. Noisy beastie and could be too much overkill for what you need. Used a walbro in my brothers eb-xr8 that is still going well after three years but would hesitate before putting one on any car I own.
A bosch 040 isn't a straight swap either - you will have to do some bending and or cutting of the pump bracket. If you want a straight swap the nismo ones will fit straight in, or a GTR pump (i think). I ended up using a walbro one which fit onto the original fuel pump/cradle - not perfectly, but without permanently modifiying anything.
If you do end up deciding on an 040 though, I have a brand new, unopened, one for sale...
Edited by Chris-06R
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
