OK, so here's a pic of my centre console
What I would like to do, is move the Aircon controls up to right under the air vents, so as to have space for a full double-din head unit, or even two single-din headunits (1 CD and 1 EQ headunit - both pioneer). If I get an aftermarket headunit/s then I will be taking the screen on top of the dash out as well, and replacing it with a 3 gauge cluster, even if some of the gauges don't have function with the N/A NEO engine.
I won't have a use for the screen unless I can rig it up for GPS or something and just have it sitting in it's operating postion permanantly instead of it retracting when I switch the car off.
Anyone?
https://www.sau.com.au/forums/topic/251898-air-conditioner-controls/
I've just been through that and you'll need to change the whole centre console bit to a standard r34 ie. get it from wreckers or Nissan.
normal r34s with the triple guage setup have different brackets holding that centre console in there and the AC fascia is wider as well as the stereo fascia is different. I paid $300 at wreckers for the centre console with brackets, ac unit with ac fascia and double din stereo fascia + triple guages and their pods.
