100bucks geez ... busting his balls there mate
my STAGEA broke of at the tee ST-AGEA ... but the glue has it hangin on still.
how hard was it to get the RS FOUR sticker off the tail gate. had this ugly stain for ages before i attacked it with cutters ... now i have a couple bright white spots, think i rubbed to hard :S
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4359619
*ouch* Common problem TJ? Or should I call you Saint Agea??
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4359697
ebay had a couple at one stage. and a search through google came up with a jap site selling also.
got mine on a self in the garrage.
looks better debadged and more mysterious
On a shelf in your garage huh? How much for the STAGEA lettering on the tailgate? Also the twin unicorn emblem for the front grill, you got that too? If you're willing to sell, I'm willing to buy. Name your price.
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4359863
um ok 80 bucks delivered in a soft pad bag! oh and to get that stuff off behind the rsfours badge, i had to look back into the past, back into the days of my primary school, when we used to get graffiti and sticky crap off our desks with.........none other than EUCAPLYTUS oil :3some: hope that helps mate, you can get it from any chemist for about 5 buckss
and nah mate, RENT???????????/ are you serious lol, thats what parents are good for haha, so i can save up and buy my performace mods lol
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4360014
Hmmm $80 bucks. Getting closer. Take a picture of them and post it here so i can see them. I never buy anything without at least looking at it first.
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4360116
hey mate so if ya want i have now off just for you the stagea tailgate badge, the ffront unicorn badge and the front rs four badge so if ya want all 3 of them i'll do a special deal 100 bucks delivered mmkay :down: heres some pics i took this morning for ya
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4360644
hey mate so if ya want i have now off just for you the stagea tailgate badge, the ffront unicorn badge and the front rs four badge so if ya want all 3 of them i'll do a special deal 100 bucks delivered mmkay :( heres some pics i took this morning for ya
I only need the front unicorn badge and the STAGEA tailgate badge. They look on good condition. What price for the two and what say you?
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4372930
I had no front Unicorn badge so I got a N/a grille, which I wanted anyway. The RS FOUR badge off the grille is now mounted under the P/S headlight??? No its not a Volvo, it's an Audi, can't you see the RSFOUR badge. LOL
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4373561
hrmm ill have to consult my accountant....
lol jokes
um i dunno lets say 70 bucks delivered? how does that sound to you mate? what do you think?
$70.00 sounds better. Alright send them to me via COD. What's your email address and i'll then give you my postal address. Ta
https://www.sau.com.au/forums/topic/251916-stagea-badges/#findComment-4375202
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
